Some reinstalls of software after upgrade from Buster to Bullseye fail Topic is solved
Re: Some reinstalls of software after upgrade from Buster to Bullseye fail
The error log stays empty, correct?
fhals
Post by fhals »
Now it's getting wicked.
Your steps were the ones I intended to do...
When you do a
sudo -u mysql /usr/sbin/mariadbd
is your result 'Illegal instruction' too?
ahh I did not notice that there is an additional user joining the topic.
Anyway, DietPi version is totally unrelated as it has no influence in MariaDB functionality.
nigelf
Post by nigelf »
to reply in order:
yes the error.log stays empty (in as much as it doesn't even get created)
yes sudo -u mysql /usr/sbin/mariadbd gives 'illegal instruction'
guys could you both share your system details
#### Required Information
- DietPi version | cat /boot/dietpi/.version
- Distro version | echo $G_DISTRO_NAME $G_RASPBIAN
- Kernel version | uname -a
- SBC model | echo $G_HW_MODEL_NAME or (EG: RPi3)
fhals
Post by fhals »
G_DIETPI_VERSION_CORE=7
G_DIETPI_VERSION_SUB=6
G_DIETPI_VERSION_RC=2
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
G_LIVE_PATCH_STATUS[0]='not applicable'
G_LIVE_PATCH_STATUS[1]='not applied'
G_LIVE_PATCH_STATUS[2]='not applied'
G_LIVE_PATCH_STATUS[3]='not applied'
bullseye
uname -a
Linux DietPi 3.16.85+ #1 SMP PREEMPT Tue Jun 30 19:02:35 CEST 2020 aarch64 GNU/Linux
Odroid C2 (aarch64)
nigelf
Post by nigelf »
G_GITBRANCH='beta'
bullseye
Linux 3.16.85+ #1 SMP PREEMPT aarch64 GNU/Linux
Odroid C2 (aarch64) (!!)
nigelf
Post by nigelf »
..it might be worth mentioning that error.log seems to be disabled by default (/etc/mysql/mariadb.conf.d/50-server.conf)
# When running under systemd, error logging goes via stdout/stderr to journald
# and when running legacy init error logging goes to syslog due to
# /etc/mysql/conf.d/mariadb.conf.d/50-mysqld_safe.cnf
# Enable this if you want to have error logging into a separate file
#log_error = /var/log/mysql/error.log
so no surprise that it doesn't get written to ;-)
nigelf
Post by nigelf »
looking for Odroid C2 mariadb issues is interesting though I haven't yet found 'the' solution
https://forum.odroid.com/viewtopic.php?t=40016
fhals
Post by fhals »
How could I overlook this?
Great find.
Unfortunately nothing will be logged. Neither in error, nor in general log.
