Some reinstalls of software after upgrade from Buster to Bullseye fail Topic is solved
fhals
Re: Some reinstalls of software after upgrade from Buster to Bullseye fail
Post by fhals »
Thank you both, php reinstalled successfully.
Had to leave out the downgrade option ('--allow-downgrade is not understood in combination with the other options')
Feels like I'm close to final bullseye, but
mariadb fails to start.
Reinstallation went fine:
 Step: Installing MariaDB: Persistent cached file-per-table database server
[ INFO ] DietPi-Software | Preparing database directory at: /mnt/dietpi_userdata/mysql
[ INFO ] DietPi-Software | /mnt/dietpi_userdata/mysql exists, will migrate containing databases
[  OK  ] DietPi-Software | rm -Rf /var/lib/mysql
[  OK  ] DietPi-Software | ln -s /mnt/dietpi_userdata/mysql /var/lib/mysql
[ INFO ] DietPi-Software | APT install for: mariadb-server, please wait...
[  OK  ] DietPi-Software | APT install for: mariadb-server
[ INFO ] DietPi-Software | Removing obsolete SysV mysql service
[  OK  ] DietPi-Software | update-rc.d mysql remove
Job for mariadb.service failed because a fatal signal was delivered to the control process.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
Not much details, journalctl shows:
Sep 27 16:41:59 DietPi systemd[1]: Starting MariaDB 10.5.11 database server...
░░ Subject: A start job for unit mariadb.service has begun execution
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit mariadb.service has begun execution.
░░ The job identifier is 23352.
Sep 27 16:42:00 DietPi systemd[1]: mariadb.service: Main process exited, code=killed, status=4/ILL
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit mariadb.service has exited.
░░ The process' exit code is 'killed' and its exit status is 4.
Sep 27 16:42:00 DietPi systemd[1]: mariadb.service: Failed with result 'signal'.
░░ Subject: Unit failed
░░ The unit mariadb.service has entered the 'failed' state with result 'signal'.
Sep 27 16:42:00 DietPi systemd[1]: Failed to start MariaDB 10.5.11 database server.
░░ Subject: A start job for unit mariadb.service has failed
░░ A start job for unit mariadb.service has finished with a failure.
░░ The job identifier is 23352 and the job result is failed.
systemctl:
● mariadb.service - MariaDB 10.5.11 database server
     Loaded: loaded (/lib/systemd/system/mariadb.service; disabled; vendor preset: enabled)
     Active: activating (auto-restart) (Result: signal) since Mon 2021-09-27 16:47:05 CEST; 715ms ago
       Docs: man:mariadbd(8)
             https://mariadb.com/kb/en/library/systemd/
    Process: 36577 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
    Process: 36579 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Process: 36582 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
    Process: 36644 ExecStart=/usr/sbin/mariadbd $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=killed, signal=ILL)
   Main PID: 36644 (code=killed, signal=ILL)
My external HD is up and running, my pre-upgrade databases are still there. Symbolic link at /var/lib/mysql sends me there too.
I can't detect any hint in the failed status, do you?
Thanks & regards, Frans
ok let's try the usual debug steps
systemctl restart mariadb.service
journalctl -u mariadb
cat /var/log/mysql/error.log
readlink /var/lib/mysql
readlink -f /var/lib/mysql
fhals
Post by fhals »
Sorry, nothing new here:
Journal file /var/log/journal/fbd586f15aab42cdab084639a1d2b2cc/system.journal is truncated, ignoring file.
-- Journal begins at Tue 2021-09-28 08:39:39 CEST, ends at Tue 2021-09-28 08:41:05 CEST. --
Sep 28 08:39:44 DietPi systemd[1]: mariadb.service: Scheduled restart job, restart counter is at 8001.
Sep 28 08:39:44 DietPi systemd[1]: Stopped MariaDB 10.5.11 database server.
Sep 28 08:39:44 DietPi systemd[1]: Starting MariaDB 10.5.11 database server...
Sep 28 08:39:45 DietPi systemd[1]: mariadb.service: Main process exited, code=killed, status=4/ILL
Sep 28 08:39:45 DietPi systemd[1]: mariadb.service: Failed with result 'signal'.
Sep 28 08:39:45 DietPi systemd[1]: Failed to start MariaDB 10.5.11 database server.
Repeating from here with increasing counter
error.log is empty, while user mysql has write access. No more mysql.logs:
ls -la /var/log
drwxr-s---   2 mysql    adm                   60 Feb 17  2019 mysql
ls -la /var/log/mysql
-rw-rw----  1 mysql adm    0 Sep 24 11:29 error.log
/mnt/usb_1/dietpi_userdata/mysql
could you try to reboot and repeat the test?
Unfortunately no real error message present at the moment.
fhals
Post by fhals »
Did it again.
Exactly the same- no results.
When I compare /lib/systemd/system/mariadb.service with my last running backup version, both are nearly identical.
Small diff:
NEW:
[Install]
WantedBy=multi-user.target
CapabilityBoundingSet=CAP_IPC_LOCK CAP_DAC_OVERRIDE CAP_AUDIT_WRITE
PrivateDevices=false
OLD:
[Install]
Alias=mysql.service
Alias=mysqld.service
PrivateDevices=true
fhals
Post by fhals »
Information on Mariadb failing to start without errors is barely to find.
Should I try to uninstall and install it again instead of reinstall (viewtopic.php?f=11&t=8729&start=10)?
I have a full backup of all databases, but would like to keep my nextcloud installation.
Can you try whether it shows more output when switching to console log:
echo 'skip_log_error=1' > /etc/mysql/mariadb.conf.d/99-disable-file-logging.cnf
sleep 5
fhals
Post by fhals »
Sep 28 19:58:27 DietPi systemd[1]: Starting MariaDB 10.5.11 database server...
Sep 28 19:58:28 DietPi sh[48435]: error: Found option without preceding group in config file: /etc/mysql/mariadb.conf.d/99-disable-file-logging.cnf at line: 1
Sep 28 19:58:28 DietPi mariadbd[48493]: error: Found option without preceding group in config file: /etc/mysql/mariadb.conf.d/99-disable-file-logging.cnf at line: 1
Sep 28 19:58:28 DietPi systemd[1]: mariadb.service: Main process exited, code=killed, status=4/ILL
Sep 28 19:58:28 DietPi systemd[1]: mariadb.service: Failed with result 'signal'.
Sep 28 19:58:28 DietPi systemd[1]: Failed to start MariaDB 10.5.11 database server.
Edit:
Just added a '[mysqld]' prior the skip_log_error=1.
No shown errors, like before:
Sep 28 20:01:15 DietPi systemd[1]: Starting MariaDB 10.5.11 database server...
Sep 28 20:01:15 DietPi systemd[1]: mariadb.service: Main process exited, code=killed, status=4/ILL
Sep 28 20:01:15 DietPi systemd[1]: mariadb.service: Failed with result 'signal'.
Sep 28 20:01:15 DietPi systemd[1]: Failed to start MariaDB 10.5.11 database server.
quite strange that there is no output at all
Ah yes sorry, the config section was missing. Hmm, and if you start it manually from console:
sudo -u mariadb /usr/sbin/mariadbd
