[rpi 4 8gb] Can't start Kodi
Re: [rpi 4 8gb] Can't start Kodi
I will test Kodi on ARMv8 RPi4 once back home to be able to check screen output.
igor
Post by igor »
Same error here. I did a fresh install.
- RPI 4 (8GB)
- ARMv7 32-bit image (bullseye)
I tried a fresh install using ARMv8 64-bit image and Kodi worked. However, CEC doesn't work and we know 32-bit is more stable.
I have been using DietPi arm7 (buster) for a year and I have zero problems. I decided to upgrade to the bullseye, and I can't run Kodi anymore. Feeling that regret... :cry:
It works well on RPi Zero and RPi 2, so it is definitely an issue with the two HDMI ports on RPi 4, or another difference of the RPi 4 GPU. Btw, Kodi since Bullseye has native GBM support builtin on Debian as well, so it can be started without X server then as well. Would be interesting if this works:
apt reinstall --allow-downgrade kodi
kodi --standalone
Also would be interesting if performance is fine with this Debian package. In case we can skip the own Kodi build on Bullseye for RPi 2 and up, or at least for RPi 4, depending on how well it performs.
So we need to find out how to force Kodi starting on the foreground screen.
I have a RPi4B 8GB connected with a single HDMI port connected. HDMI 2 is empty. I could test Kodi but I'm nearly sure it was working in past. What version to test? ARMv6/7/8 ?
@MichaIng
I did a test using RPi4B 8GB and it dosn't matter if I use ARMv7 or ARMv8. In both cases Kodi is started, but on a screen I'm not able to see. Unfortunately I have a single Micro HDMI cable only not being able to connect 2 screens at the same time. Therefore I couldn't check if Kodi is running on 2nd screen. Maybe I will need to get a 2nd Micro HDMI cable :? But best to my knowledge HDMI ports are not active if not connected. Still the question where Kodi is started on :roll:
root       585   576  0 11:59 tty1     00:00:00 /bin/sh /usr/local/bin/kodi --standalone
root       617   585 14 11:59 tty1     00:02:14 /usr/local/lib/kodi/kodi-gbm --standalone
Strange. But it must have something to do with the to ports, as on all other RPi models it works fine :?. Does it make a difference whether you use the --standalone flag or not?
And another interesting test would be whether the Debian Kodi package works:
apt purge kodi
apt install kodi
kodi --standalone
EDIT: Ah, as you said 64-bit, means with the Debian Kodi package it's the same?
yes correct, it's same on our 32bit build as well as on the Debian 64bit build
I'll have a look into the RPi build's scripts, I remember there was some workaround to switch to a different VT, probably it is exactly for that issue.
but I'm pretty sure I had kodi working in past. Strange one.
