let's encrypt cert for Pi-hole web Interface on top of DietPi Topic is solved
Re: let's encrypt cert for Pi-hole web Interface on top of DietPi
ok this explains the different web server root. Therefore the workaround is needed in your case. As long as you don't plan to run any other web server application (like NextCloud) it should be fine.
