Kodi Error
Exatic
Re: Kodi Error
Post by Exatic »
Good evening. I took some of the ideas for a spin:
- Installed DietPI ARM64 on a new card. Kodi Autostart works fine but only as root. If I remember correctly it says something like /dev/tty0 permission denied during xinit() for dietpi user.
- I also did not get CEC-Module (TV remote to control Kodi) working. Historically, such issues have been resolved by unplugging pi & TV for 10 minutes. Did not get the chance to test myself but suggest to the user above who had the same issue.
Back to ARMv7 (Dietpi 32bit):
- Tried running Kodi from autostart as root on arm32. Still the same problem.
- Tried starting up as normal, and then switch the HDMI cable to port 2 when the Libva message occur. Nothing on the TV.
- Tried vcgenmod display_power 0 7. from terminal and restart Kodi. Same issue.
- Tried hdmi_ignore_hotplug:1=0 and hdmi_force_hotplug:0=1 in /boot/config.txt. Same issue.
While it has been an unsuccessful day, it is good to see it nothing wrong with my particular dietpi installation as other are experiencing the same problem.
A bit on the side. Is It worth changing to the ARM64 image for my RPI4 4GB? I did a extensive backup this morning in case it was my DietPi it was something wrong with, and it appeals to make the shift now when everything is ready and setup.
Re: Kodi Error
usually there is no real benefit of 64bit over 32bit.
ISquishWorms
Re: Kodi Error
Post by ISquishWorms »
Good evening,
Just for clarification although I have a Pi3 and a Pi4 I am running Kodi on the Pi3. I have not tried running Kodi on my Pi4 although if it helps for testing I can because I backed it up only this morning and wiped the SD card for a fresh install of Bullseye. I decided to take the fresh install approach and reconfig/restore files manually rather than try and update to Bullseye.
So on my Pi3 (which I also wiped and installed Bullseye) I do get an error message when loading Kodi but its interface is displayed on the TV. I have not yet tried to play any video yet as I am unable to get the TV controller to work with Kodi, this was working prior to installing Bullseye.
@Exatic Thanks for the tip about unplugging the pi & TV for 10 minutes I will give this a try. It is probably just some setting I have set wrong but you never know it is worth a go. As for switching to 64bit, personally on my Pi4 (8 gig) I am taking the advice of DietPi support (Joulinar) along with MichaIng and sticking with 32bit at least until there is a stable final release of Raspberry Pi OS.
ISquishWorms.
igor
Re: Kodi Error
Post by igor »
Same error here. I did a fresh install.
- RPI 4 (8GB)
- ARMv7 32-bit image (bullseye)
I tried a fresh install using ARMv8 64-bit image and Kodi worked. However, CEC doesn't work and we know 32-bit is more stable.
I have been using DietPi arm7 (buster) for a year and I have zero problems. I decided to upgrade to the bullseye, and I can't run Kodi anymore. Feeling that regret... :cry:
Re: Kodi Error
it doesn't make sense to post the same into 2 different topics, even if we have multiple of them open.
