Kodi Error
Re: Kodi Error
The command to start Kodi would be
startkodi
Exatic
Re: Kodi Error
Post by Exatic »
Still the same error
dietpi@DietPi:~$ startkodi
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
libva info: VA-API version 1.10.0
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Re: Kodi Error
pls can you provide some more information on your system
  • Kernel version | uname -a
Exatic
Re: Kodi Error
Post by Exatic »
dietpi@DietPi:~$ cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=7
G_DIETPI_VERSION_SUB=6
G_DIETPI_VERSION_RC=2
G_GITBRANCH='master'
G_GITOWNER='MichaIng'
G_LIVE_PATCH_STATUS[0]='not applicable'
G_LIVE_PATCH_STATUS[1]='applied'
G_LIVE_PATCH_STATUS[2]='applied'
G_LIVE_PATCH_STATUS[3]='applied'
G_LIVE_PATCH_STATUS[4]='not applicable'
dietpi@DietPi:~$ echo $G_DISTRO_NAME $G_RASPBIAN
bullseye 1
dietpi@DietPi:~$ uname -a
Linux DietPi 5.10.63-v7l+ #1457 SMP Tue Sep 28 11:26:14 BST 2021 armv7l GNU/Linux
Running on a RPI4. I manually upgraded from DietPi Buster to Bullseye following the blog entry.
Re: Kodi Error
Can you please try to reinstall Kodi, to assure that also the fKMS driver is used etc:
dietpi-software reinstall 31
reboot
I also see the libva error, but Kodi starts fine despite this.
Exatic
Re: Kodi Error
Post by Exatic »
Still nothing. The Kodi is running (both in ps x) and it makes its startup sound, but nothing on the screen. I have set DietPi to autostart directly to Kodi (user dietpi) from dietpi-config, however it is just showing the terminal with the libra error. Could it be needed to run through a DE?
I will try a fresh install on a new card tomorrow. Was hoping to avoid it through upgrading instead, and so far everything else is working fine.
Re: Kodi Error
could you try using user root to start kodi on autostart.
Re: Kodi Error
Like if it was running on a different screen :?.
ISquishWorms
Re: Kodi Error
Post by ISquishWorms »
This is a guess on my part but could the problem they are having be something to do with the Pi4 having two HDMI outputs? I ask this only because on my Pi3 I did a complete fresh install for Bullseye including installing Kodi and I get the same error but Kodi does load and displays its user interface on the TV.
I am having my own problem though of not being able to navigate using my TV controller anymore since the fresh install of Bullseye and Kodi. This is probably down to something I am doing wrong like a setting that needs changing but at the moment I am lost on how to fix this.
Thank you for DietPi I have been using it for a few years now on a Pi3 and Pi4 it is my goto.
ISquishWorms
Re: Kodi Error
Indeed this seems to be the issue, same as here: viewtopic.php?p=38517#p38517
Probably for some reason the second unused screen/HDMI port is used when starting Kodi via GBM from console. Probably it works when actively disabling the second HDMI port, or there is another way to force it using the 1st/foreground screen/port, despite a second one is available.
