curl: error while loading shared libraries
Re: curl: error while loading shared libraries
if you have time, and local access, it would be good to check what the issue is. Do you know if something like ifupdown package got removed during Bullseye upgrade?
omavoss
Post by omavoss »
Hello, thanks for the tip.
I read and work according to
viewtopic.php?t=8954&start=10
and will get back to you. Thank you so far.
yes that issue was related to PiHole being removed and there is a dangerous question by the PiHole removal tool. It is asking to remove not needed dependency, which will break your system if you confirm :roll:
omavoss
Post by omavoss »
there is no PiHole installed on the system, it runs Baikal, Yacy, Wireguard and OpenVPN on it.
When I finish the upgrade by "rule", I go to the local display screen of the system with my notebook and take pictures with my smartphone. This may take a few more minutes . . .
Take your time, no need to rush.
omavoss
Post by omavoss »
the promised pictures in the attachment.
If you want me to enter more or other commands, please let me know.
Thank you very much.
omavoss
Post by omavoss »
Two another pictures:
omavoss
Post by omavoss »
Another pictures:
Interesting no ethernet adapter available. Looks like the kernel module is not loaded correctly.
@MichaIng
Any ideas?
omavoss
Post by omavoss »
For today, one last picture; if it serves the further development of the update to Bullseye, I can do without the Baikal calendar for a few more days and enter more commands and send pictures of them.
