curl: error while loading shared libraries
omavoss
Re: curl: error while loading shared libraries
Post by omavoss »
@Joulinar:
I have already performed the procedure of uninstalling and installing curl three times without success.
root@DietPi:~# G_AGP curl
[ INFO ] APT purge for: curl, please wait...
(Lese Datenbank ... 98955 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von curl (7.64.0-4+deb10u2) ...
[  OK  ] APT purge for: curl
root@DietPi:~# reboot
Using username "root".
root@192.168.115.30's password:
Linux DietPi 5.10.60-v7+ #1449 SMP Wed Aug 25 15:00:01 BST 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
 DietPi v7.4.2 (beta) : 19:45 - So 12.09.2021
 - Device model : RPi 3 Model B (armv7l)
 - Uptime : up 1 minute
 - CPU temp : WARNING: 70'C : 158'F (Reducing the life of your device)
 - LAN IP : 192.168.115.30 (eth0)
 - Freespace (RootFS) : 1,6G
 - Freespace (userdata) : 1,6G
/boot/dietpi/func/dietpi-banner: Zeile 245: curl: Kommando nicht gefunden.
root@DietPi:~# G_AGI curl
[ INFO ] APT install for: curl, please wait...
Vormals nicht ausgewähltes Paket curl wird gewählt.
(Lese Datenbank ... 98947 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../curl_7.64.0-4+deb10u2_armhf.deb ...
Entpacken von curl (7.64.0-4+deb10u2) ...
curl (7.64.0-4+deb10u2) wird eingerichtet ...
[  OK  ] APT install for: curl
root@DietPi:~# curl --help
curl: error while loading shared libraries: libhogweed.so.6: cannot open shared object file: No such file or directory
Are there any other hints please?
Thank you very much.
I don't have any other idea than competing the upgrade to Bullseye.
alleyu2
Re: Failed to upgrade from Debian Buster to Bullseye
Post by alleyu2 »
Sorry for the trouble. My terminal just crashed during the apt upgrade and there was some issue upgrading again. I did a dietpi-restore and I am facing some issue with some of the libraries. For eg: when I run curl I get the following error
Same issue in Radarrr and Sonarr
MediaInfo Library could not be loaded Unable to load shared library 'libmediainfo.so.0' or one of its dependencies. In order to help diagnose loading problems, consider setting the LD_DEBUG environment variable: liblibmediainfo.so.0: cannot open shared object file: No such file or directory
Is this something to do with my environment variables? I did a find in my system for libhogweed.so.6, however, I was not able to find this library.
Can you please try:
ldd $(which curl)
ldconfig
ldd $(which curl)
Somehow the linked libraries are noch changed back after restoring the backup, especially with curl we had this base before.
alleyu2
Post by alleyu2 »
Here is the output
ldd $(which curl)
        linux-vdso.so.1 (0xbed30000)
        /usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0xb6f66000)
        libcurl.so.4 => /usr/lib/arm-linux-gnueabihf/libcurl.so.4 (0xb6ed0000)
        libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb6ea5000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6e7b000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6d2d000)
        /lib/ld-linux-armhf.so.3 (0xb6f7b000)
        libnghttp2.so.14 => /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14 (0xb6cfe000)
        libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb6cd2000)
        librtmp.so.1 => /usr/lib/arm-linux-gnueabihf/librtmp.so.1 (0xb6ca9000)
        libssh2.so.1 => /usr/lib/arm-linux-gnueabihf/libssh2.so.1 (0xb6c73000)
        libpsl.so.5 => /usr/lib/arm-linux-gnueabihf/libpsl.so.5 (0xb6c53000)
        libssl.so.1.1 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.1 (0xb6bd4000)
        libcrypto.so.1.1 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1 (0xb69ba000)
        libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb6970000)
        libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb68b5000)
        libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb6875000)
        libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb6862000)
        libldap_r-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2 (0xb680d000)
        liblber-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2 (0xb67f1000)
        libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xb6675000)
        libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb64d2000)
        libhogweed.so.6 => not found
        libnettle.so.8 => not found
        libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xb6459000)
        libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb637f000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb636c000)
        libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb6352000)
        libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb633e000)
        libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb631a000)
        libsasl2.so.2 => /usr/lib/arm-linux-gnueabihf/libsasl2.so.2 (0xb62f3000)
        libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb61ee000)
        libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xb61ce000)
        libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xb618a000)
        libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xb614b000)
        libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xb6121000)
        libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb6109000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb60dc000)
root@DietPi-Pi4:~# ldconfig
root@DietPi-Pi4:~# ldd $(which curl)
        linux-vdso.so.1 (0xbeff5000)
        /usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0xb6fac000)
        libcurl.so.4 => /usr/lib/arm-linux-gnueabihf/libcurl.so.4 (0xb6f16000)
        libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb6eeb000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6ec1000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6d73000)
        /lib/ld-linux-armhf.so.3 (0xb6fc1000)
        libnghttp2.so.14 => /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14 (0xb6d44000)
        libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb6d18000)
        librtmp.so.1 => /usr/lib/arm-linux-gnueabihf/librtmp.so.1 (0xb6cef000)
        libssh2.so.1 => /usr/lib/arm-linux-gnueabihf/libssh2.so.1 (0xb6cb9000)
        libpsl.so.5 => /usr/lib/arm-linux-gnueabihf/libpsl.so.5 (0xb6c99000)
        libssl.so.1.1 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.1 (0xb6c1a000)
        libcrypto.so.1.1 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1 (0xb6a00000)
        libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb69b6000)
        libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb68fb000)
        libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb68bb000)
        libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb68a8000)
        libldap_r-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2 (0xb6853000)
        liblber-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2 (0xb6837000)
        libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xb66bb000)
        libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb6518000)
        libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xb649f000)
        libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb63c5000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb63b2000)
        libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb6398000)
        libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb6384000)
        libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb6360000)
        libsasl2.so.2 => /usr/lib/arm-linux-gnueabihf/libsasl2.so.2 (0xb6339000)
        libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb6234000)
        libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xb6214000)
        libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xb61d0000)
        libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xb6191000)
        libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xb6167000)
        libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb614f000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb6122000)
Strange, there is even another library linked which does not exist on Buster. As of something wrote those inside manually :?. A little down the list you see the two correct library versions.
Lets simply remove that faulty links manually. They are not part of the original Buster curl, so something also added then manually:
apt install patchelf
patchelf --remove-needed libhogweed.so.6 $(which curl)
patchelf --remove-needed libnettle.so.8 $(which curl)
alleyu2
Post by alleyu2 »
I executed the two commands but the problems persists. I tried reinstalling and rebooting the system but it still won't help. I still get the same error.
ldd output
        linux-vdso.so.1 (0xbef00000)
        /usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0xb6ef1000)
        libcurl.so.4 => /usr/lib/arm-linux-gnueabihf/libcurl.so.4 (0xb6e5b000)
        libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb6e30000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6e06000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6cb8000)
        /lib/ld-linux-armhf.so.3 (0xb6f06000)
        libnghttp2.so.14 => /usr/lib/arm-linux-gnueabihf/libnghttp2.so.14 (0xb6c89000)
        libidn2.so.0 => /usr/lib/arm-linux-gnueabihf/libidn2.so.0 (0xb6c5d000)
        librtmp.so.1 => /usr/lib/arm-linux-gnueabihf/librtmp.so.1 (0xb6c34000)
        libssh2.so.1 => /usr/lib/arm-linux-gnueabihf/libssh2.so.1 (0xb6bfe000)
        libpsl.so.5 => /usr/lib/arm-linux-gnueabihf/libpsl.so.5 (0xb6bde000)
        libssl.so.1.1 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.1 (0xb6b5f000)
        libcrypto.so.1.1 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1 (0xb6945000)
        libgssapi_krb5.so.2 => /usr/lib/arm-linux-gnueabihf/libgssapi_krb5.so.2 (0xb68fb000)
        libkrb5.so.3 => /usr/lib/arm-linux-gnueabihf/libkrb5.so.3 (0xb6840000)
        libk5crypto.so.3 => /usr/lib/arm-linux-gnueabihf/libk5crypto.so.3 (0xb6800000)
        libcom_err.so.2 => /lib/arm-linux-gnueabihf/libcom_err.so.2 (0xb67ed000)
        libldap_r-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/libldap_r-2.4.so.2 (0xb6798000)
        liblber-2.4.so.2 => /usr/lib/arm-linux-gnueabihf/liblber-2.4.so.2 (0xb677c000)
        libunistring.so.2 => /usr/lib/arm-linux-gnueabihf/libunistring.so.2 (0xb6600000)
        libgnutls.so.30 => /usr/lib/arm-linux-gnueabihf/libgnutls.so.30 (0xb645d000)
        libgmp.so.10 => /usr/lib/arm-linux-gnueabihf/libgmp.so.10 (0xb63e4000)
        libgcrypt.so.20 => /lib/arm-linux-gnueabihf/libgcrypt.so.20 (0xb630a000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb62f7000)
        libkrb5support.so.0 => /usr/lib/arm-linux-gnueabihf/libkrb5support.so.0 (0xb62dd000)
        libkeyutils.so.1 => /lib/arm-linux-gnueabihf/libkeyutils.so.1 (0xb62c9000)
        libresolv.so.2 => /lib/arm-linux-gnueabihf/libresolv.so.2 (0xb62a5000)
        libsasl2.so.2 => /usr/lib/arm-linux-gnueabihf/libsasl2.so.2 (0xb627e000)
        libp11-kit.so.0 => /usr/lib/arm-linux-gnueabihf/libp11-kit.so.0 (0xb6179000)
        libtasn1.so.6 => /usr/lib/arm-linux-gnueabihf/libtasn1.so.6 (0xb6159000)
        libnettle.so.6 => /usr/lib/arm-linux-gnueabihf/libnettle.so.6 (0xb6115000)
        libhogweed.so.4 => /usr/lib/arm-linux-gnueabihf/libhogweed.so.4 (0xb60d6000)
        libgpg-error.so.0 => /lib/arm-linux-gnueabihf/libgpg-error.so.0 (0xb60ac000)
        libffi.so.6 => /usr/lib/arm-linux-gnueabihf/libffi.so.6 (0xb6094000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb6067000)
omavoss
dietpi-update failed
Post by omavoss »
the following error message:
 DietPi v7.4.2 (beta) : 09:54 - Do 16.09.2021
 - Uptime : up 1 hour, 42 minutes
 - CPU temp : 48'C : 118'F (Optimal temperature)
 DietPi Team     : MichaIng (lead), Daniel Knight (founder), Joulinar (support)
 Image by        : DietPi Core Team (pre-image: Raspbian Lite)
 Web             : https://dietpi.com | https://twitter.com/DietPi_
 Patreon Legends : Camry2731
 Contribute      : https://dietpi.com/contribute.html
 DietPi Hosting  : Powered by https://myvirtualserver.com
 dietpi-config   : Feature rich configuration tool for your device
 htop            : Resource monitor
 cpu             : Shows CPU information and stats
root@DietPi:~# dietpi-update
 DietPi-Update
 Phase: Checking for available DietPi update
[ INFO ] DietPi-Update | Getting latest version from: https://raw.githubusercontent.com/MichaIng/DietPi/beta/.update/version
[FAILED] DietPi-Update | Unable to get latest version.
[ INFO ] DietPi-Update | Please check the target Git repository and your network connection, then rerun dietpi-update.
[ INFO ] DietPi-Update | If this error persists, please report at: https://github.com/MichaIng/DietPi/issues
[ INFO ] DietPi-Update | APT update, please wait...
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:3 https://archive.raspberrypi.org/debian buster InRelease
Reading package lists...
[  OK  ] DietPi-Update | APT update
[ INFO ] DietPi-Update | No APT upgrades were found, not creating file: /run/dietpi/.apt_updates
What can I do?
Many greetings and thank you.
@omavoss
there is no need to open an additional issue on this as you still have the challange with CURL. Therefore I moved your post into the existing one.
@alleyu2
pls could you try following
G_AGP curl
apt install --reinstall libhogweed4
reboot
apt install curl
