curl: error while loading shared libraries
novitibo
Post by novitibo »
hi.
│ Checking URL: https://raw.githubusercontent.com/MichaIng/DietPi/master/.conf/dps_31/99-dietpi-kodi.rules             │
│  - Command: curl -ILfvm 5 https://raw.githubusercontent.com/MichaIng/DietPi/master/.conf/dps_31/99-dietpi-kodi.rules │
│  - Exit code: 127        │
│  - DietPi version: v7.4.2 (MichaIng/master) | HW_MODEL: 3 | HW_ARCH: 2 | DISTRO: 5                                   │
│  - Error log:        │
│ curl: error while loading shared libraries: libhogweed.so.6: cannot open shared object file: No such file or         │
│ directory
Change command into https://github.com/MichaIng/DietPi/blob ... kodi.rules (found on internet) doesn't work.
What can I do?
Similar issue found with command dietpi-update:
[ INFO ] DietPi-Update | Getting latest version from: https://raw.githubusercontent.com/MichaIng/DietPi/master/.update/version
curl: error while loading shared libraries: libhogweed.so.6: cannot open shared object file: No such file or directory
[FAILED] DietPi-Update | Unable to get latest version.
What can I do?
Re: curl not working after unsuccessful buster>bullseye upgrade
did you restore your system after the unsuccessful buster>bullseye upgrade ?
At the moment it looks like curl command is looking for Bullseye libraries. And of course they are not available on Buster. And what was the issue with the bullseye upgrade?
novitibo
Post by novitibo »
Ssh connection was not possible. Local ip not found. I didnt get time to investigate, so I restored backup. But...
How can i change the path for curl into buster version?
How did you restore your system?
novitibo
Post by novitibo »
Dietpi-backup... Restore
you did a reboot afterwards, right?
novitibo
Post by novitibo »
correct
you could try to remove curl and reinstall it afterwards
G_AGP curl
G_AGI curl
novitibo
Post by novitibo »
No luck there. Same issue:
dietpi-update:
novitibo
Post by novitibo »
now
https://raw.githubusercontent.com/Micha ... kodi.rules
and
https://raw.githubusercontent.com/Micha ... te/version
link works,
but
do you have any idea?
