Another Issue with update from Buster to Bullseye - nothing to update? Topic is solved
DarrenHill
Re: Another Issue with update from Buster to Bullseye - nothing to update?
Post by DarrenHill »
OK, so we can call this one now fully updated and working? Nothing more to do except the auto-purge?
yes you should be able to continue if all your apps are working. Just ensure PiHole DNS resolution is working as well, by checking your clients ;)
DarrenHill
Yes, all seems to be working with PiHole too. So can call that a working update.
I had done the removal of ui and the wireguard list before, so I think your suggestion of rm -v /etc/apt/preferences.d/* was the winner here to get things unstuck.
Thanks for the support :)
in meantime we update our blog post to reflect these changes as well.
https://dietpi.com/blog/?p=811#2.2.2-ch ... ge-sources
DarrenHill
Looks good to me.
Now to make a backup card image and then on with the rest of the day.
Another issue successfully resolved :)
