problem while trying to upgrade to Bullseye following your blog post Topic is solved
Re: problem while trying to upgrade to Bullseye following your blog post
remove both Tiger and Real. reboot. and check if there is no process running afterwards
ps -ef | grep vnc
as well check no LISTEN vnc process
ss -tulpn | grep LISTEN
manilx
Post by manilx »
Uninstalled RealVNC. Rebooted.
root@Unify:~# ps -ef | grep vnc
root      1991  1458  0 09:18 pts/0    00:00:00 grep vnc
root@Unify:~# ss -tulpn | grep LISTEN
tcp   LISTEN 0      4096                  0.0.0.0:10000      0.0.0.0:*    users:(("miniserv.pl",pid=1616,fd=5))
tcp   LISTEN 0      1024        192.168.1.51%eth0:25552      0.0.0.0:*    users:(("zerotier-one",pid=547,fd=17))
tcp   LISTEN 0      1024        192.168.1.51%eth0:25553      0.0.0.0:*    users:(("zerotier-one",pid=547,fd=19))
tcp   LISTEN 0      128                 127.0.0.1:28017      0.0.0.0:*    users:(("mongod",pid=335,fd=10))
tcp   LISTEN 0      128                   0.0.0.0:22         0.0.0.0:*    users:(("sshd",pid=662,fd=3))
tcp   LISTEN 0      4096                127.0.0.1:8125       0.0.0.0:*    users:(("netdata",pid=705,fd=53))
tcp   LISTEN 0      4096             192.168.1.51:19999      0.0.0.0:*    users:(("netdata",pid=705,fd=4))
tcp   LISTEN 0      1024        192.168.1.51%eth0:9993       0.0.0.0:*    users:(("zerotier-one",pid=547,fd=15))
tcp   LISTEN 0      1024                127.0.0.1:9993       0.0.0.0:*    users:(("zerotier-one",pid=547,fd=6))
tcp   LISTEN 0      128                 127.0.0.1:27017      0.0.0.0:*    users:(("mongod",pid=335,fd=9))
tcp   LISTEN 0      128                 127.0.0.1:27117      0.0.0.0:*    users:(("mongod",pid=1736,fd=7))
tcp   LISTEN 0      100                         *:8880             *:*    users:(("java",pid=680,fd=167))
tcp   LISTEN 0      100                         *:8080             *:*    users:(("java",pid=680,fd=163))
tcp   LISTEN 0      128                      [::]:22            [::]:*    users:(("sshd",pid=662,fd=4))
tcp   LISTEN 0      100                         *:8443             *:*    users:(("java",pid=680,fd=205))
tcp   LISTEN 0      4096                    [::1]:8125          [::]:*    users:(("netdata",pid=705,fd=52))
tcp   LISTEN 0      50                          *:6789             *:*    users:(("java",pid=680,fd=196))
tcp   LISTEN 0      1024                    [::1]:9993          [::]:*    users:(("zerotier-one",pid=547,fd=7))
tcp   LISTEN 0      100                         *:8843             *:*    users:(("java",pid=680,fd=218))
install Real now and perform both checks again afterwards
manilx
Post by manilx »
Reinstalled Real. Can't connect to 5900.
Rebooted, still no go.
tcp   LISTEN 0      4096             0.0.0.0:10000      0.0.0.0:*    users:(("miniserv.pl",pid=1804,fd=5))
tcp   LISTEN 0      1024   192.168.1.51%eth0:25552      0.0.0.0:*    users:(("zerotier-one",pid=552,fd=17))
tcp   LISTEN 0      128              0.0.0.0:6001       0.0.0.0:*    users:(("Xvnc-core",pid=707,fd=1))
tcp   LISTEN 0      1024   192.168.1.51%eth0:25553      0.0.0.0:*    users:(("zerotier-one",pid=552,fd=19))
tcp   LISTEN 0      128            127.0.0.1:28017      0.0.0.0:*    users:(("mongod",pid=337,fd=10))
tcp   LISTEN 0      128              0.0.0.0:22         0.0.0.0:*    users:(("sshd",pid=668,fd=3))
tcp   LISTEN 0      4096           127.0.0.1:8125       0.0.0.0:*    users:(("netdata",pid=861,fd=47))
tcp   LISTEN 0      4096        192.168.1.51:19999      0.0.0.0:*    users:(("netdata",pid=861,fd=4))
tcp   LISTEN 0      1024   192.168.1.51%eth0:9993       0.0.0.0:*    users:(("zerotier-one",pid=552,fd=15))
tcp   LISTEN 0      1024           127.0.0.1:9993       0.0.0.0:*    users:(("zerotier-one",pid=552,fd=6))
tcp   LISTEN 0      128            127.0.0.1:27017      0.0.0.0:*    users:(("mongod",pid=337,fd=9))
tcp   LISTEN 0      5                0.0.0.0:5901       0.0.0.0:*    users:(("Xvnc-core",pid=707,fd=7))
tcp   LISTEN 0      100                    *:8880             *:*    users:(("java",pid=1052,fd=167))
tcp   LISTEN 3      100                    *:8080             *:*    users:(("java",pid=1052,fd=163))
tcp   LISTEN 0      128                 [::]:6001          [::]:*    users:(("Xvnc-core",pid=707,fd=0))
tcp   LISTEN 0      128                 [::]:22            [::]:*    users:(("sshd",pid=668,fd=4))
tcp   LISTEN 0      4096               [::1]:8125          [::]:*    users:(("netdata",pid=861,fd=46))
tcp   LISTEN 0      1024               [::1]:9993          [::]:*    users:(("zerotier-one",pid=552,fd=7))
tcp   LISTEN 0      5                   [::]:5901          [::]:*    users:(("Xvnc-core",pid=707,fd=6))
you are trying to connect to wrong port. RealVNC is running on 5901
manilx
Post by manilx »
I can connect only via the RealVNC app.
The app I normally use "Royal TSX" can't connect. Tried port 5900 and 5901.
Why not using RealVNC app? I checked it on my Windows box as well as Android Mobile. Both are working fine and can connect to RealVNC server.
manilx
Post by manilx »
Joulinar wrote: Mon Aug 30, 2021 10:33 am Why not using RealVNC app? I checked it on my Windows box as well as Android Mobile. Both are working fine and can connect to RealVNC server.
Royal TSX can connect to a LOT of services and protocols. I have defined there connections to 40 servers (vnc, terminal, vmware, rdp etc). It has apps for macos and ios. Highly recommended.
Will change back to Tiger. I hope not to have bothered to much but helped a bit "debugging" Bullseye stuff.....
A reboot after uninstall of Tiger is pertinent and perhaps you could put it in the uninstall script.
at least you could have tried RealVNC native app, just to check if it is working in general.
manilx
Post by manilx »
Joulinar wrote: Mon Aug 30, 2021 10:51 am at least you could have tried RealVNC native app, just to check if it is working in general.
I did and mentioned it. "I can connect only via the RealVNC app." ;)
