Error while updating linux image Topic is solved
CbIP
Re: Error while updating linux image
Post by CbIP »
OK. Should I just delete the installed image?
Don't do anything at the moment. I would recommend to wait on @MichaIng . Usually he has good ideas on such issues.
CbIP
Post by CbIP »
Wilco
Luckily this cloud VM kernel is not loaded by the physical RPi anyway. These would never be automatically installed by any other Debian package or any of our software options, but indeed one output line indicated that it was pulled as dependency by another APT package, a 3rd party package most likely:
linux-image-cloud-arm64/buster-backports,now 5.10.46-4~bpo10+1 arm64 [installed,automatic]
Can you try to purge it (do not confirm!) and paste the list of packages which would be purged as a result?
apt purge linux-image-5.10.0-0.bpo.7-cloud-arm64 linux-image-5.10.0-0.bpo.8-cloud-arm64linux-image-5.9.0-0.bpo.5-cloud-arm64 linux-image-cloud-arm64
That list should then show the culprit package which for strange reasons has that cloud kernel package as dependency.
That is a kernel for e.g. ESXi on ARM guests, actually good to know about it. Also I'll just test linux-image-cloud-amd64 on our supported VMs, as it is much smaller than the regular x86_64 kernel :).
CbIP
Post by CbIP »
Thank you for the advice!
I have executed the command and this was the output:
# apt purge linux-image-5.10.0-0.bpo.7-cloud-arm64 linux-image-5.10.0-0.bpo.8-cloud-arm64 linux-image-5.9.0-0.bpo.5-cloud-arm64 linux-image-cloud-arm64
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  cpio initramfs-tools initramfs-tools-core klibc-utils libklibc linux-base
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
  linux-image-5.10.0-0.bpo.7-cloud-arm64* linux-image-5.10.0-0.bpo.8-cloud-arm64* linux-image-5.9.0-0.bpo.5-cloud-arm64* linux-image-cloud-arm64*
0 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 163 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
Strange, nothing else would be purged. Not sure why the package has the "automatic" mark then. However, so you can confirm to purge them and also remove the other packages those pulled again as dependency, like the initramfs, which is not required on RPi:
apt purge --autoremove linux-image-5.10.0-0.bpo.7-cloud-arm64 linux-image-5.10.0-0.bpo.8-cloud-arm64 linux-image-5.9.0-0.bpo.5-cloud-arm64 linux-image-cloud-arm64
CbIP
Post by CbIP »
I have purged all the linux-image* packages you mentioned + their dependencies (via --autoremove) and updated DietPi to 7.5.2.
Everything works fine! Thank you!!!
The case is now resolved. How can I mark it?
I marked it as resolved now
