Unable to access Sonarr, Radarr, and Lidarr Web UI
wiggley
Re: Unable to access Sonarr, Radarr, and Lidarr Web UI
Post by wiggley »
DietPi v7.5.2 : 14:39 - Thu 08/26/2021
 - Device model : RPi 4 Model B (aarch64)
 - CPU temp : 55'C : 131'F (Running warm, but safe)
 - LAN IP : 10.0.1.12 (eth0)
 - MOTD : DietPi v7.5 brings further fixes for Debian Bullseye
[Info] Bootstrap: Starting Sonarr - /usr/lib/sonarr/bin/Sonarr.exe - Version 3.0.6.1196
[Info] AppFolderInfo: Data directory is being overridden to [/mnt/dietpi_userdata/sonarr]
[Info] Router: Application mode: Interactive
[Info] MigrationLogger: *** Checking database for required migrations data source=/mnt/dietpi_userdata/sonarr/sonarr.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
	Native Crash Reporting
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
	Native stacktrace:
	0x555a184208 - /usr/bin/mono :
	0x555a184524 - /usr/bin/mono :
	0x555a159130 - /usr/bin/mono :
	0x555a11f650 - /usr/bin/mono :
	0x7fa66d67c0 - linux-vdso.so.1 : __kernel_rt_sigreturn
	0x7fa0bdc5fc - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 : sqlite3_stmt_readonly
	0x7fa0c16aec - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 :
	0x7fa0be5158 - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 :
	0x7fa0be51fc - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 :
	0x7fa0bf5be4 - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 :
	0x7fa0bff234 - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 : sqlite3_initialize
	0x7fa0ca568c - /usr/lib/aarch64-linux-gnu/libsqlite3.so.0 :
	0x7fa0897930 - Unknown
	Telemetry Dumper:
Pkilling 0x548176150912x from 0x548252999696x
Pkilling 0x548180353408x from 0x548252999696x
Pkilling 0x548200419712x from 0x548252999696x
Pkilling 0x548178252160x from 0x548252999696x
Entering thread summarizer pause from 0x548252999696x
Finished thread summarizer pause from 0x548252999696x.
Failed to create breadcrumb file (null)/crash_hash_0xc72444bb4
Could not exec mono-hang-watchdog, expected on path '/etc/../bin/mono-hang-watchdog' (errno 2)
Waiting for dumping threads to resume
	External Debugger Dump:
mono_gdb_render_native_backtraces not supported on this platform, unable to find gdb or lldb
	Basic Fault Address Reporting
Memory around native instruction pointer (0x7fa0bdc5fc):0x7fa0bdc5ec  00 00 80 d2 c0 03 5f d6 1f 20 03 d5 80 00 00 b4  ......_.. ......
0x7fa0bdc5fc  00 18 43 39 00 00 00 12 c0 03 5f d6 20 00 80 52  ..C9......_. ..R
0x7fa0bdc60c  c0 03 5f d6 e1 03 00 aa 00 00 80 52 e1 00 00 b4  .._........R....
0x7fa0bdc61c  23 24 40 b9 62 b4 81 52 42 be a5 72 00 00 80 52  #$@.b..RB..r...R
	Managed Stacktrace:
	  at <unknown> <0xffffffff>
	  at System.Data.SQLite.UnsafeNativeMethods:sqlite3_open_v2 <0x00007>
	  at System.Data.SQLite.SQLite3:Open <0x00187>
	  at System.Data.SQLite.SQLiteConnection:Open <0x0103b>
	  at FluentMigrator.Runner.Processors.GenericProcessorBase:EnsureConnectionIsOpen <0x0006f>
	  at FluentMigrator.Runner.Processors.SQLite.SQLiteProcessor:Exists <0x0002b>
	  at FluentMigrator.Runner.Processors.SQLite.SQLiteProcessor:TableExists <0x0006f>
	  at FluentMigrator.Runner.VersionLoader:get_AlreadyCreatedVersionTable <0x0009b>
	  at FluentMigrator.Runner.VersionLoader:LoadVersionInfo <0x0006f>
	  at FluentMigrator.Runner.VersionLoader:.ctor <0x0057f>
	  at FluentMigrator.Runner.MigrationRunner:.ctor <0x0082b>
	  at FluentMigrator.Runner.MigrationRunner:.ctor <0x0004b>
	  at NzbDrone.Core.Datastore.Migration.Framework.MigrationController:Migrate <0x001db>
	  at NzbDrone.Core.Datastore.DbFactory:CreateMain <0x0007b>
	  at NzbDrone.Core.Datastore.DbFactory:Create <0x000c7>
	  at NzbDrone.Core.Datastore.DbFactory:Create <0x0004f>
	  at NzbDrone.Core.Datastore.DbFactory:RegisterDatabase <0x0005f>
	  at NzbDrone.Host.NzbDroneServiceFactory:Start <0x0015f>
	  at NzbDrone.Host.Router:Route <0x0017b>
	  at NzbDrone.Host.Bootstrap:Start <0x0011b>
	  at NzbDrone.Host.Bootstrap:Start <0x00237>
	  at NzbDrone.Console.ConsoleApp:Main <0x000d3>
	  at <Module>:runtime_invoke_void_object <0x000eb>
Aborted
@MichaIng
I'm not 100% sure what the issue with mono is
Which Debian version is it?
Radarr and Lidarr work now, right?
I just tested it on a Bullseye VM where it works fine. Will run another test on aarch64.
EDIT: Works well on aarch64 here, too.
In the meantime, what is the issue with Nginx?
journalctl -u nginx
cat /var/log/nginx/error.log
