Chromium on DietPi = No Sync ("This Browser is not Secure")
dwr
Re: Chromium on DietPi = No Sync ("This Browser is not Secure")
Post by dwr »
Joulinar wrote: Mon Aug 23, 2021 11:49 pm Yes PR is a Pull Request. This is actually to add code to DietPi scripts. Means real coding ;)
You could open your request via GitHub Issues as well as FeatHub request. But don't expect a miracle.
Gotcha - so, for example, I have a few "suggestions" so I would create one 'Pull Request' for each item:
1. AutoKey
2. Vivaldi
3. Webhookd
4. Conky
Then create a 'FeatHub' suggestion with a link to each 'Pull Request'? I just don't want to mess anything up on the Diet Pi GitHub page, or put anything anywhere that it shouldn't be. 8)
Probably we misunderstood. Creating a PR would mean to add the new DietPi code already.
Best to create FeatHub request first if you like to add your software request. Than we will see how many join you.
dwr
Post by dwr »
Joulinar wrote: Tue Aug 24, 2021 12:43 am Probably we misunderstood. Creating a PR would mean to add the new DietPi code already.
My misunderstanding! The PR would be for the Chromium Issues, whereas the FeatHub and GitHub Issue creation would be for 'Feature/Software Requests'. Understood!
Thanks!
