USB3 Boot Hard Drive Corruption Issues
in03
Re: USB3 Boot Hard Drive Corruption Issues
Post by in03 »
MichaIng wrote: Thu Aug 19, 2021 9:47 pm The absolute maximum power they can serve, shared across all USB ports, is 1.2A/6W[...] use a PSU which is explicitly designed to power devices, holding voltage in a sufficiently tight range even on usage fluctuations.
Hey! Thanks for that, MichaIng. That's great to know.
I think I was definitely hitting that power limit when I got all those I/O errors.
I'll make sure I'm getting stable power to the drive then, no phone charger.
Finally my powered drive adapter came!
I powered off the Pi, swapped the adapters, but alas... It refused to boot. I believe I got the same error as earlier or maybe a variation:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
I know the exact error is important to know, so I took a photo on my phone, but as luck would have it, my photo came out corrupt...
I got the same error on all USB ports 2.0 and 3.0, and when I switched back to the other enclosure just to be sure (it's been running fine for weeks now, but I haven't been pushing it hard), same error. So I popped the drive out and repaired the filesystems with my other Linux machine (I can't seem to get the hold shift trick working on my Pi), but now when I attempt to boot I am greeted with a blank screen.
I wish I had a more straightforward problem, sorry guys. I was under the impression that booting from SSD would be simple? Am I doing something dreadfully wrong? Is there an official Pi guide with a list of compatible drives and enclosures? It seems like I'm walking a tightrope over corruption city here, haha.
The only reason I switched to SSD was for longevity. I've heard the SD cards wear out quickly if you run busy webservers or the like. I want to run Caddy, Nextcloud, Syncthing, Home Assistant and Mycroft, maybe a few other things to fiddle with, so I thought it would be worth the switch with all that data moving around.
In the interest of looking at alternatives, I'm aware I can move most of the DietPi offical apps' userdata to an external drive which might be a good compromise? But some of the unofficial apps I run will still be writing with some regularity to the root partition. Are there any downsides to moving the whole root partition to SSD and just leaving boot on SD?
Any ideas welcome, guys.
Sorry for the messy confusing post :?
Have you also check the FAT partition for errors? This can be done on Windows as well, including repairing it. When bootup doesn't show any output, likely parts of the kernel or bootloader are damaged. As on RPi, all are actual files on the FAT partition, this can be quite easily repaired from Windows (or any other OS, of course). Can you paste the content (with file sizes) of the FAT partition, so we can check if something is missing or has the wrong size and then re-add or re-place it with a fresh file from GitHub: https://github.com/raspberrypi/firmware ... table/boot
I remember there was some challenges for RPi to work together with specific adapter using JMicron Technology controller. As well there was a need to add an UAS blacklist quirk sometimes. Or to delay the start from SSD to give time for the disk to come up.
Another option is to boot from a USB stick and have RootFS transferred to the SSD?
Ah yes good point about the UAS issue. Let's first see if the boot files are all there and healthy. As there was some filesystem corruption, not unlikely that the FAT partition was affected as well.
in03
Post by in03 »
Hey guys, thanks for the responses. I have been repairing the boot partition as well as root. It took a few hours, but that blank screen eventually threw up some more errors:
EXT4-fs-error (device sda2): __ext4_find_entry:1536: inode #2: comm (sh): reading directory Iblock 0
EXT4-fs-error (device sda2): __ext4_find_entry:1536: inode #2: comm (modprobe): reading directory Iblock 0
EXT4-fs-error (device sda2): __ext4_find_entry:1536: inode #8108: comm (sh): reading directory Iblock 0
And that just loops in a pattern.
So I left it off for the night and tried the fsck again this morning, seems we're in business!
No other USB devices plugged in, using one of the USB2 ports.
The first unpowered enclosure I had is indeed JMicron chipset. I recall only setting
USB_MSD_PWR_OFF_TIME=0
in the EEPROM bootloader as recommended.
After success again with the JMicron enclosure, I tried the new powered one and finally have the kernel panic in its full form for all to see:
Kernel panic - not syncing with VFX: unable to mount root-fs on unknown block(8,2)
CPU: 1 PID: 1 Comm: swapper/O Not tainted 5.10.52-v8+ #1441
Hardware name: Raspberry  Pi 5 Model B Rev 1.4 (DT)
Call trace:
dump_backtrace+0x0/0x1b8
show_stack+0x20/0x30
dump_stack+0xf0/0x158
panic+0x18c/0x38c
mount_block_root+0x240/0x25c
mount_root+0x114/0x144
prepare_namespace+0x134/0x174
kernel_init_freeable+0x2a0/0x2e4
kernel_init+0x1c/0x120
ret_from_fork+0x10/0x30
SMP: stopping secondary CPUs
Kernel Offset: disabled
CPU features: 0x0240022, 6002000
Memory limit: none
--- [  end Kernel panic - not syncing: VFS: Unable to mount root-fs on unknown block(8,2)  ]---
Popped it back into the JMicron enclosure, started it again and I'm back at the login shell.
Looks like it doesn't like the chipset of my new powered enclosure then hey?
Thanks Joulinar for that USB stick suggestion! I didn't think of that. If this doesn't pan out, I'll probably go that route.
