auto update setting Topic is solved
Re: auto update setting
Can you check
ls -la /etc/apt/apt.conf.d/
manilx
Post by manilx »
Joulinar wrote: Fri Jul 30, 2021 9:03 pm Can you check
drwxr-xr-x 2 root root 4096 Jul 30 01:28 .
drwxr-xr-x 7 root root 4096 Nov 26  2020 ..
-r--r--r-- 1 root root  440 Jul 30 01:28 01autoremove-kernels
-rw-r--r-- 1 root root  182 Dec 27  2020 70debconf
-rw-r--r-- 1 root root 1370 Jul 25 09:25 97dietpi
-rw-r--r-- 1 root root  212 Dec 27  2020 99-dietpi-cache
Both your systems are on latest release 7.4?
Let's check as well following
ls -la /var/tmp/dietpi/logs/
manilx
Post by manilx »
Yes, they are.
drwxrwxr-x 3 dietpi dietpi    4096 Jun  4 11:49 .
drwxrwxr-x 3 dietpi dietpi    4096 Sep 10  2020 ..
-rw-r--r-- 1 root   root      5473 Sep 10  2020 dietpi-firstboot.log
-rw-r--r-- 1 root   root   1284625 Oct 20  2020 dietpi-firstrun-setup.log
-rw-r--r-- 1 root   root       322 Jul 30 19:52 dietpi-ramlog.log
-rw-r--r-- 1 root   root       156 May  8 10:15 dietpi-ramlog_disable_debug.log
drwxr-xr-t 7 root   root      4096 Jul 16 10:12 dietpi-ramlog_store
-rw-r--r-- 1 root   root      4853 Jul 25 09:25 dietpi-update.log
-rw-r--r-- 1 root   root     69524 Jul 30 01:28 dietpi-upgrade_apt.log
-rw-r--r-- 1 root   root      1073 Dec 18  2020 fs_partition_resize.log
I see dietpi-upgrade_apt.log present. This indicates automatic apt package update is active via DietPi scripts. Can you share the file?
Let's verify config settings
cat /boot/dietpi.txt | grep CONFIG_CHECK_APT_UPDATES
manilx
Post by manilx »
root@DietPi:~# cat /boot/dietpi.txt | grep CONFIG_CHECK_APT_UPDATES
CONFIG_CHECK_APT_UPDATES=2
(Guess I did miss this line previously, sorry)
Actually a bit above is the line: CONFIG_CHECK_APT_UPDATES=1
dietpi.txt
(12.67 KiB) Downloaded 16 times
manilx
Post by manilx »
Changed this:
# DietPi checks for updates: Allows DietPi to check for updates on a daily basis and boot using a less 1 KiB file download.
CONFIG_CHECK_DIETPI_UPDATES=1
to:
# Daily check for APT package updates: 0=disable | 1=check only | 2=check and upgrade automatically
# - Upgrade logs can be found at: /var/tmp/dietpi/logs/dietpi-update_apt.log
and deleted CONFIG_CHECK_APT_UPDATES=2 from the end of the file.
Seems OK now and I now how to disable ;)
THX!!!!!
not sure what you mean but in the file shared, there was just a single line containing CONFIG_CHECK_APT_UPDATES=2. Which is totaly fine if you like to update apt packages automatically. Doesn't matter if it is at the end of the file or somewhere in the middle.
manilx
Post by manilx »
Joulinar wrote: Fri Jul 30, 2021 9:36 pm not sure what you mean but in the file shared, there was just a single line containing CONFIG_CHECK_APT_UPDATES=2. Which is totaly fine if you like to update apt packages automatically. Doesn't matter if it is at the end of the file or somewhere in the middle.
I just edited the file and put
after
And deleted the line near the end.
Cleaner now with the comments I have on the other pie.
So all good!
ok good
