Transmission error
Re: Transmission error
You could try adding your local client IP to rpc-whitelist. For doing this, you would need to stop Transmission first, perform the change and start Transmission afterwards. It's important to have Transmission stopped while doing the change. But I would wonder if this has any effect as whitelist-enabled is not active.
trendy
Post by trendy »
There seem to be some lines missing. Please post the whole file, redacting the password.
cat /etc/transmission-daemon/settings.json
jhmc93
Post by jhmc93 »
trendy wrote: Thu Jul 15, 2021 10:12 am There seem to be some lines missing. Please post the whole file, redacting the password.
Here you go:
"umask": 7,
    "message-level": 0,
    "rpc-whitelist-enabled": false,
    "trash-original-torrent-files": true,
    "ratio-limit-enabled": true,
    "ratio-limit": 1.1,
    "idle-seeding-limit-enabled": true,
    "idle-seeding-limit": 1,
    "upload-slots-per-torrent": 5,
    "peer-limit-global": 40,
    "download-queue-size": 3,
    "cache-size-mb": 788,
    "blocklist-enabled": 0,
    "download-dir": "/mnt/dietpi_userdata/downloads",
    "download-limit": 100,
    "download-limit-enabled": 0,
    "encryption": 2,
    "max-peers-global": 200,
    "peer-port": 51413,
    "pex-enabled": 1,
    "port-forwarding-enabled": true,
    "rpc-authentication-required": 1,
    "rpc-port": 9091,
    "rpc-username": "root",
    "rpc-whitelist": "127.0.0.1",
    "upload-limit": 100,
    "upload-limit-enabled": 0
trendy
Post by trendy »
You have some weird values here:
rpc-authentication-required is boolean, not integer. Same for pex-enabled.
Maybe the default configuration file is overridden by environmental variables such as TRANSMISSION_HOME.
Also rpc-host-whitelist-enabled is missing and by default is true.
Maybe the quickest way to fix it is to set the IPs in rpc-host-whitelist and restart the service.
jhmc93
Post by jhmc93 »
trendy wrote: Thu Jul 15, 2021 3:56 pm You have some weird values here:
How would I do that?, I’m still quite new to Linux
or remove transmission and perform a new installation to get correct config file. Might be fastest.
