Can't log into MineOS - Software password incorrect Topic is solved
pintapass
Re: Can't log into MineOS - Software password incorrect
Post by pintapass »
Should probably branch this off into a new thread now that the login issue has been identified, but I'm unable to launch/create any servers with MineOS under Bullseye. They start and then stop a few seconds later. I first tried running the built-in version of Java, then tried with different versions (e.g., 16.0.2, 17-aarch64), but nothing's working. Would report the logs messages/errors, but I'm still learning how to view log output using the command line.
Here's what I'm seeing with the "systemctl status mineos" command:
Sep 28 18:31:43 DietPi MineOS[668]: info: [Bullseye] 192.168.X.XX issued command : "start"
Sep 28 18:31:43 DietPi MineOS[668]: info: [Bullseye] received request "start"
Sep 28 18:31:45 DietPi MineOS[668]: error: { Error: connect ECONNREFUSED 127.0.0.1:25565
Sep 28 18:31:45 DietPi MineOS[668]:     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1088:14)
Sep 28 18:31:45 DietPi MineOS[668]:   errno: 'ECONNREFUSED',
Sep 28 18:31:45 DietPi MineOS[668]:   code: 'ECONNREFUSED',
Sep 28 18:31:45 DietPi MineOS[668]:   syscall: 'connect',
Sep 28 18:31:45 DietPi MineOS[668]:   address: '127.0.0.1',
Sep 28 18:31:45 DietPi MineOS[668]:   port: 25565 }
[EDIT: Never mind. I just uninstalled and reinstalled MineOS and was able to successfully create a new server.]
A reboot might have been fixed it as well as there was some internal connection issues. Probably some function was not working probably.
