RasPi gets no IP after router change Topic is solved
GreenGentleman
Re: RasPi gets no IP after router change
Post by GreenGentleman »
Joulinar wrote: Fri Jul 09, 2021 11:02 pm why are you going with such a huge IP range? If I'm not mistaken, a netmask of 255.255.0.0 will result in 65536 possible hosts :x
Usually 192.168.178.0/24 should be sufficient.
Fritzbox: 192.168.178.1 (Static)
RasPi: 192.168.178.2 (Static)
Local devices: 192.168.1.20 ff (DHCP)
Netmask 255.255.255.0
Probably, yeah - I just made the lower bound lower, so the original RasPi IP is in it. Can I just change the static IP of the RasPi in the Fritzbox, or do I have to go in the settings of the RasPi (which still doesn't work :D )?
well you could change the Fritzbox IP address too. This way you would not need to go into RPI. STATIC IP of the RPi can be changed on the RPi only. Or you place the SD card of the RPI into another Linux box and change config files manually.
Probably easiest might be to perform a change as follow
FritzBox change to 192.168.2.1\24 (255.255.255.0)
RasPi keep at 192.168.2.125
Set DHCP Server range to 192.168.2.20-192.168.2.120 (255.255.255.0)
Set DNS Server inside DHCP Server config to 192.168.2.125
My PC: set to DHCP
GreenGentleman
Thank you so much! Your configuration made everything work again.
ensure the RPi is using STATIC IP, just to be sure ;)
