lxde + kodi Topic is solved
Reindier
Re: lxde + kodi
Post by Reindier »
when i start it from console the same thing happens: see the picture
Re: lxde + kodi
this is still lxde desktop. can you go back into command line?
Reindier
Re: lxde + kodi
Post by Reindier »
this was the result on my tv screen when I run it from the command line
Re: lxde + kodi
could you try running dietpi-autostart 1 and reboot your system afterwards
Re: lxde + kodi
Can you also please verify that these packages are installed:
dpkg -l malig52-fbdev-opencl-odroid aml-libs-odroid kodi-aml-fbdev-odroid
Kodi should then start independently from any desktop or X server.
For the desktop, did try to start it as root user? Also can you show the following output:
lsmod
ls -al /dev/dri
But it actually makes sense as the GPU/driver packages for Kodi all use the framebuffer, so I guess it is expected the KMS/DRM is not available. I'll add those packages for desktop/X server installs on Odroid N2 (and C4, which behaves the same way) accordingly.
Reindier
Re: lxde + kodi
Post by Reindier »
Joulinar wrote: Mon Jul 05, 2021 2:18 pm could you try running dietpi-autostart 1 and reboot your system afterwards
I get the same screen squeezed then turns to black no output
Reindier
Re: lxde + kodi
Post by Reindier »
MichaIng wrote: Mon Jul 05, 2021 2:59 pm Can you also please verify that these packages are installed:
lsmod
ls -al /dev/dri
all packages are installed
when i run
lsmod
ls -al /dev/dri
lsmod
Module                  Size  Used by
xt_nat                 16384  38
xt_tcpudp              16384  50
xt_conntrack           16384  2
nft_meta               16384  90
ipt_MASQUERADE         16384  8
nf_nat_masquerade_ipv4    16384  1 ipt_MASQUERADE
nf_conntrack_netlink    45056  0
nft_counter            16384  89
xt_addrtype            16384  2
nft_compat             20480  100
nft_chain_nat_ipv4     16384  36
nf_conntrack_ipv4      20480  3
nf_defrag_ipv4         16384  1 nf_conntrack_ipv4
nf_nat_ipv4            16384  1 nft_chain_nat_ipv4
nf_nat                 32768  3 xt_nat,nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack          143360  6 nf_conntrack_ipv4,nf_conntrack_netlink,nf_nat_masquerade_ipv4,xt_conntrack,nf_nat_ipv4,nf_nat
nf_tables_ipv4         16384  45
nf_tables              86016  279 nft_chain_nat_ipv4,nft_compat,nf_tables_ipv4,nft_meta,nft_counter
br_netfilter           24576  0
bridge                155648  1 br_netfilter
stp                    16384  1 bridge
llc                    16384  2 bridge,stp
overlay                53248  12
mali_kbase            462848  0
i2c_meson_master       20480  0
amvdec_vp9            122880  0
amvdec_vc1             65536  0
amvdec_real            45056  0
amvdec_mmpeg4          40960  0
amvdec_mpeg4           65536  0
amvdec_mpeg12         106496  0
amvdec_mmjpeg          28672  0
amvdec_mjpeg           40960  0
amvdec_h265           147456  0
amvdec_h264mvc         57344  0
amvdec_mh264          159744  0
amvdec_h264_4k2k       69632  0
amvdec_h264           147456  0
amvdec_avs             69632  0
stream_input          180224  9 amvdec_h265,amvdec_mh264,amvdec_h264mvc,amvdec_h264_4k2k,amvdec_real,amvdec_vp9,amvdec_h264,amvdec_mpeg12,amvdec_avs
decoder_common        188416  15 amvdec_h265,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,amvdec_h264_4k2k,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mpeg4
firmware               28672  16 amvdec_h265,amvdec_mjpeg,amvdec_mh264,amvdec_mmpeg4,amvdec_h264mvc,amvdec_mmjpeg,amvdec_h264_4k2k,decoder_common,amvdec_real,stream_input,amvdec_vp9,amvdec_h264,amvdec_mpeg12,amvdec_avs,amvdec_vc1,amvdec_mpeg4
media_clock            45056  10 amvdec_h265,amvdec_mh264,amvdec_h264_4k2k,decoder_common,firmware,stream_input,amvdec_vp9,amvdec_h264,amvdec_mpeg12,amvdec_avs
ip_tables              32768  0
x_tables               49152  7 xt_nat,ip_tables,nft_compat,xt_tcpudp,ipt_MASQUERADE,xt_addrtype,xt_conntrack
ipv6                  462848  247 bridge
root@DietPi:~# ls -al /dev/dri
ls: cannot access '/dev/dri': No such file or directory
Reindier
Re: lxde + kodi
Post by Reindier »
are there other things i can try?
