PiVPN Installation/Setup Errors Topic is solved
Fourdee
Re: PiVPN Installation/Setup Errors
Post by Fourdee »
prp2 wrote:
Fourdee wrote:
Critical: Unable to locate configuration file to set static IPv4 address!
Ok, checked the PiVPN sourecode, looks like if /etc/dhcpcd.conf doesn't exist, the script fails: https://github.com/pivpn/pivpn/blob/mas ... #L331-L345
Please try creating that file, then re-running the PiVPN installation:
echo 1 > /etc/dhcpcd.conf
Perfect! It's creating the key as I type this. Many thanks!
Excellent, i'll inform this issue to the PiVPN team.
