Other Services with LetsEncrypt Topic is solved
Parkour_Lama
Re: Other Services with LetsEncrypt
Post by Parkour_Lama »
With the modification I've stated? Yes it works.
I'm pretty sure it's not the proper way to do it, but unfortunately I don't have enough knowledge about Apache do be able to figure that out, so this stopgap will be used until a more suitable solution arises.
as long as it is working you should be fine 8)
Parkour_Lama
Joulinar wrote: Wed Jul 07, 2021 1:21 am as long as it is working you should be fine 8)
Words to live by :lol:
P.S. Is it just me, or are the emojis much better now?
for me emojis seems to be same as before. :?
