Setting Up AdGuard: DNS Redirect doesn’t work Topic is solved
Re: Setting Up AdGuard: DNS Redirect doesn’t work
Let's see if there will be an answer. If not you might consider to use PiHole as it is way more flexible.
Rhizome
Post by Rhizome »
Oh boy, back into the fire :roll: lol.
Whatever that means 8)
Rhizome
Post by Rhizome »
Setting up AdGuard was more work than expected (for a beginner), but my previous experience with pihole was even more work. Which is why I migrated from pihole to adguard in the first place. :cry:
usually AGH as well as PiHole are working out of the box. There shouldn't be that much need for difficult configuration.
Rhizome
Post by Rhizome »
Installation for both is a breeze. But configuring them has been time consuming for me. That said, my SmartRG modem router GUI is pure ka-ka, poo-poo, so that hasn’t helped.
AdBlocking and DNS resolution is working out of the box. The only thing needed would be to activate the DHCP server if needed. What further configuration steps you have done?
Rhizome
Post by Rhizome »
AGH DHCP is already setup. I received a response to my question on Adguard github. One can add a DNS server option! Back to my original question: What DNS would I use so that I have internet access if the Rpi fails?
Also, this morning I also enabled ufw. Previously I had allowed port 53 without the subnet but it still blocked all access to the internet. After reading a few ufw tutorials and fiddling, I added the subnet /24 and now I have access on all devices. It was the only way I could get it to work.
53 ALLOW IN 192.168.1.0 /24
Simply use Cloudflare or Quad9 public DNS as fall back.
Rhizome
Post by Rhizome »
Well, I edited the AdGuardHome.yaml config file, but when I shut down the Rpi I lose internet access:
dhcpv4:
gateway_ip: 192.168.1.1
subnet_mask: 255.255.255.0
range_start: 192.168.1.110
range_end: 192.168.1.254
lease_duration: 86400
icmp_timeout_msec: 1000
options:
- 6 ips 9.9.9.9
- 149.112.112.112
