another Noob question: accessing Sonarr et all via browser Topic is solved
trendy
Re: another Noob question: accessing Sonarr et all via browser
Post by trendy »
Verify that the server is running:
sudo ss -anp | grep arr; sudo ss -anp | grep mono
Verify that firewall is inactive
sudo iptables -t filter -c
TWHH
Post by TWHH »
typed in both of those commands, but not sure what the response it telling me :?
If the killswitch is enabled, then yes, only SSH connections from LAN are possible currently. Without the killswitch, all LAN connections should be possible, as the LAN routes override the VPN routes. Remote connections, through the internet, aren't possible in either case, as NordVPN does not support port forwarding.
Additionally to trendy's suggested checks, we could also verify that the routes are as expected: ip r
EDIT: Please copy and paste the output of these commands here. You may mask all identifying info, of course.
TWHH
Post by TWHH »
Thanks for the help here. All appears to be OK now. Not sure what was causing that blip!
I guess you are using dietpi-vpn now, instead of the NordVPN client. ;)
TWHH
Post by TWHH »
Not sure. I think me thinking inhale downloaded the Nord client was actually me downloading the OpenVPN ‘files’.
You have been so helpful in getting me set up… and slightly less scared of Terminal commands 😎.
Massive thanks
