run Pi-hole and Own/Nextcloud alongside Topic is solved
Re: run Pi-hole and Own/Nextcloud alongside
you are running owncloud as well es nextcloud or just nextcloud??
fillip
Post by fillip »
Joulinar wrote: Mon Jun 21, 2021 12:09 am you are running owncloud as well es nextcloud or just nextcloud??
no. just nextcloud. owncloud i just installed later, to see if the problem was somehow with nextcloud. now i uninstall owncloud. but it works too now..;)
I just saw you had both config files active 8)
lrwxrwxrwx 1 root root   42 Jun 20 12:18 99-dietpi-nextcloud.conf -> ../conf-available/99-dietpi-nextcloud.conf
lrwxrwxrwx 1 root root   41 Jun 20 13:18 99-dietpi-owncloud.conf -> ../conf-available/99-dietpi-owncloud.conf
But this is fine in this case
