Home assistant fatal error Topic is solved
Re: Home assistant fatal error
What do you mean by limited version on offer? Should be the latest version and latest supported underlying Python in every case. But it is not HASSIO indeed, which is an own operating system image, if this is what you mean, so the operating system config frontend is not available. There is a Docker container available I see, result might be something in the middle between Home Assistant Core and a native Home Assistent (HASSIO) system :?.
