uninstalling Pihole Topic is solved
manilx
Re: uninstalling Pihole
Post by manilx »
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  bind9-host libbind9-161 libdns1104 libgeoip1 libirs161 libisc1100 libisccc161 libisccfg163 liblmdb0 liblwres161
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
  dhcpcd5* dnsutils*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 1044 kB disk space will be freed.
Do you want to continue? [Y/n]
What about those: bind9-host libbind9-161 libdns1104 libgeoip1 libirs161 libisc1100 libisccc161 libisccfg163 liblmdb0 liblwres161
manilx
Post by manilx »
OK. "apt autopurge "is the same as "apt autoremove" I guess.
No it's not the same. apt autoremove will leave config files in place, apt autopurge removes packages more cleanly.
Ah in case you run a Stretch image, the "autopurge" shortcut does not yet exist and it is apt --purge autoremove instead.
manilx
Post by manilx »
Used apt autopurge as suggested. All clean now. Thanks a lot!!
