[SOLVED] curl: (28) Resolving timed out after 3000 milliseconds Topic is solved
Re: curl: (28) Resolving timed out after 3000 milliseconds
I can achieve this via dietpi-config -> Network Adapter Settings
usually yes, or edit /etc/resolv.conf manually as this will be the leading file at the end
dwr
Post by dwr »
Joulinar wrote: Wed Jun 16, 2021 11:51 pm
Thanks. I actually did both as we were posting back and forth earlier this morning - just to be sure.
Anyway, all is working! Thanks again for the troubleshooting!
dwr - SpicyLimes.io
