Trying to install wireguard - Checking DNS resolver failed Topic is solved
Totila
Re: Trying to install wireguard - Checking DNS resolver failed
Post by Totila »
I havent set any specific DNS in my phone (stats certainly show that my PI is being used as only DNS when I am on Wifi, I cannot check that when I am on mobile data though).
Turns out, google chrome and vivaldi show two DNS servers checking with https://www.perfect-privacy.com/de/tests/dns-leaktest
Firefox only shows my public IP and therefore blocks ads as expected when I am on mobile data.
So, Chrome and chrome-based phone browsers are bad as they use hard-coded DNS servers it seems.
Can you confirm your end? Which browser are you using?
Not sure if this is really a good test. Anyway, on my mobile it doesn't matter if I use Chrome, Edge or Firefox. Ads are blocked on all my Apps and browser.
Maybe some setting in Chrome. Probably you could try to reset the app like delete data, delete temp data, try to uninstall updates as much as possible. Once done install it from play store again.
Totila
Post by Totila »
What is a good test then?
I set chrome to factory default (and reinstalled) and still same result. Ads are not being blocked, tcpdump doesnt show any output.
I am on Android 9 (fwiw)
trendy
Post by trendy »
Totila wrote: Mon Jun 07, 2021 10:57 amPihole listens on all interfaces
And must permit all origins, because the android client is more than a hop away.
Also make sure that the browsers are not using hardcoded DNS or DNS over HTTPS
Totila
Post by Totila »
I did but that didnt change anything unfortunately.
How would I do that?
I only know that firefox 'seems' different to chrome as on firefox ads are being blocked. I didnt find a settings on chrome to disable any predefined DNS (if google would even present that to the user)
trendy
Post by trendy »
It would help to troubleshoot a bit. Install tcpdump and verify that you can see packets in and out.
tcpdump -evn udp port 53 try to resolv something from the android, then hit Ctrl-c, copy the output and paste here.
Firefox also has an option to use DNS over HTTPS and it is visible under proxy settings.
Totila
Post by Totila »
I resolved https://dietpi.com
There was NO terminal output using google chrome on my Android (on mobile data).
Using Firefox gave me this:
12:04:18.210314 b8:27:eb:cd:43:a1 > 2c:3a:fd:25:52:bf, ethertype IPv4 (0x0800), length 81: (tos 0x0, ttl 64, id 51864, offset 0, flags [none], proto UDP (17), length 67)
    192.168.200.2.10697 > 173.245.59.176.53: 57555% [1au] A? dieTpi.cOm. (39)
12:04:18.228748 2c:3a:fd:25:52:bf > b8:27:eb:cd:43:a1, ethertype IPv4 (0x0800), length 219: (tos 0x0, ttl 58, id 43469, offset 0, flags [DF], proto UDP (17), length 205)
    173.245.59.176.53 > 192.168.200.2.10697: 57555*- 3/0/1 dieTpi.cOm. A 172.67.173.4, dieTpi.cOm. A 104.21.96.47, dieTpi.cOm. RRSIG (177)
12:04:19.312236 b8:27:eb:cd:43:a1 > 2c:3a:fd:25:52:bf, ethertype IPv4 (0x0800), length 81: (tos 0x0, ttl 64, id 47404, offset 0, flags [none], proto UDP (17), length 67)
    192.168.200.2.33236 > 173.245.58.167.53: 10152% [1au] A? DiEtpi.CoM. (39)
12:04:19.324875 2c:3a:fd:25:52:bf > b8:27:eb:cd:43:a1, ethertype IPv4 (0x0800), length 219: (tos 0x0, ttl 58, id 37310, offset 0, flags [DF], proto UDP (17), length 205)
    173.245.58.167.53 > 192.168.200.2.33236: 10152*- 3/0/1 DiEtpi.CoM. A 104.21.96.47, DiEtpi.CoM. A 172.67.173.4, DiEtpi.CoM. RRSIG (177)
I couldnt find any proxy settings on the android firefox.
Well we are running in circle. I guess we already know that some apps seems to use a different DNS than other apps. But this is something special on the client/mobile device. And honestly, I don't know how this is possible. On my Android mobile device this is not the case.
In fact, Wireguard is working as server, PiHole is accepting the request but due to whatever reason Chrome mobile app is using a different DNS than the one specify in the Wireguard client.
Totila
Post by Totila »
Then let's leave it here.
Many thanks for your efforts. Much appreciated. At least the home setup is working flawlessly.
Some things will remain a mystery.
Thanks again.
T
probably you have another mobile device you can test on.
