Errors during LXDE & TigerVNC dietpi-software install? Topic is solved
baremetaloctopus
Re: Errors during LXDE & TigerVNC dietpi-software install?
Post by baremetaloctopus »
With the extra characters where I input Y I tried it again and the same occured, still it aborts, without the extra characters.
root@DietPi:~# apt update && apt upgrade
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 https://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
root@DietPi:~# dpkg --configure -a
Setting up libxml2:armhf (2.9.4+dfsg1-7+deb10u1) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Calculating upgrade... Done
The following packages will be upgraded:
  shared-mime-info
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 762 kB of archives.
After this operation, 4933 kB of additional disk space will be used.
Do you want to continue? [Y/n] ^[[28~Y
Abort.
you could try following
apt update && apt upgrade -y
baremetaloctopus
That seemed to work:
root@DietPi:~# apt update && apt upgrade -y
  shared-mime-info
Get:1 http://ftp.heanet.ie/mirrors/raspbian/raspbian buster/main armhf shared-mime-info armhf 1.10-1 [762 kB]
Fetched 762 kB in 2s (380 kB/s)
(Reading database ... 23976 files and directories currently installed.)
Preparing to unpack .../shared-mime-info_1.10-1_armhf.deb ...
Unpacking shared-mime-info (1.10-1) over (1.10-1) ...
Setting up shared-mime-info (1.10-1) ...
If that works, try to install your software
baremetaloctopus
Worked until lightdm. If relevant I am still logged in as root:
Unpacking lightdm (1.26.0-4) ...
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/102-lightdm_1.26.0-4        _armhf.deb (--unpack):
 unable to stat './usr/share/locale/tl/LC_MESSAGES' (which I was about to instal        l): Input/output error
dpkg: error while cleaning up:
 unable to remove newly-extracted version of '/usr/share/locale/th/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/tg/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/te/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ta/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/sv/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/sr/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/sq/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/sl/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/sk/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/si/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/shn/LC_MESSAGES/        lightdm.mo': Read-only file system
 unable to remove newly-installed version of '/usr/share/locale/shn/LC_MESSAGES'        : Read-only file system
 unable to remove newly-installed version of '/usr/share/locale/shn': Read-only        file system
 unable to remove newly-extracted version of '/usr/share/locale/sd/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/sc/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-installed version of '/usr/share/locale/sc/LC_MESSAGES':        Read-only file system
 unable to remove newly-installed version of '/usr/share/locale/sc': Read-only f        ile system
 unable to remove newly-extracted version of '/usr/share/locale/ru/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ro/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/pt_BR/LC_MESSAGE        S/lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/pt/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/pl/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/pa/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/oc/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/nn/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/nl/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/nb/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/my/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ms/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/mr/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ml/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/mi/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/mhr/LC_MESSAGES/        lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/lv/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/lt/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/lb/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ku/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ko/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/kn/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/km/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/kk/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ja/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/it/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/is/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/id/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ia/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/hu/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/hr/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/hi/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/he/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/gu/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/gl/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/gd/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/fy/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/fr/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/fo/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/fi/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/fa/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/eu/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/et/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/es/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/eo/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/en_GB/LC_MESSAGE        S/lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/en_CA/LC_MESSAGE        S/lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/en_AU/LC_MESSAGE        S/lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/el/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/de/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/da/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/cs/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ckb/LC_MESSAGES/        lightdm.mo': Read-only file system
 unable to remove newly-installed version of '/usr/share/locale/ckb/LC_MESSAGES'        : Read-only file system
 unable to remove newly-installed version of '/usr/share/locale/ckb': Read-only        file system
 unable to remove newly-extracted version of '/usr/share/locale/ca@valencia/LC_M        ESSAGES/lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ca/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/bs/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/br/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/bo/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/bn/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/bg/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/be/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/az/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ast/LC_MESSAGES/        lightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/ar/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/an/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/locale/af/LC_MESSAGES/l        ightdm.mo': Read-only file system
 unable to remove newly-extracted version of '/usr/share/lintian/overrides/light        dm': Read-only file system
 unable to remove newly-extracted version of '/usr/share/lightdm/lightdm.conf.d/        01_debian.conf': Read-only file system
 unable to remove newly-installed version of '/usr/share/lightdm/lightdm.conf.d'        : Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/xdmcp.pa        ge': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/write-gr        eeter.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/vnc.page        ': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/user-swi        tching.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/user-lis        t.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/standard        -authentication.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/seat.pag        e': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/remote-s        essions.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/local-se        ssions.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/legal.xm        l': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/index.pa        ge': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/guest.pa        ge': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/diagnost        ics.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/default-        session.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/default-        greeter.page': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/config.p        age': Read-only file system
 unable to remove newly-extracted version of '/usr/share/help/C/lightdm/autologi        n.page': Read-only file system
 unable to remove newly-installed version of '/usr/share/help/C/lightdm': Read-o        nly file system
 unable to remove newly-installed version of '/usr/share/help/C': Read-only file        system
 unable to remove newly-installed version of '/usr/share/help': Read-only file s        ystem
 unable to remove newly-extracted version of '/usr/share/doc/lightdm/copyright':        Read-only file system
 unable to remove newly-extracted version of '/usr/share/doc/lightdm/changelog.g        z': Read-only file system
 unable to remove newly-extracted version of '/usr/share/doc/lightdm/changelog.D        ebian.gz': Read-only file system
 unable to remove newly-installed version of '/usr/share/doc/lightdm': Read-only        file system
 unable to remove newly-extracted version of '/usr/share/dbus-1/interfaces/org.f        reedesktop.DisplayManager.AccountsService.xml': Read-only file system
 unable to remove newly-installed version of '/usr/share/dbus-1/interfaces': Rea        d-only file system
 unable to remove newly-extracted version of '/usr/share/bash-completion/complet        ions/lightdm': Read-only file system
 unable to remove newly-extracted version of '/usr/share/bash-completion/complet        ions/dm-tool': Read-only file system
 unable to remove newly-installed version of '/usr/share/accountsservice/interfa        ces': Read-only file system
 unable to remove newly-installed version of '/usr/share/accountsservice': Read-        only file system
 unable to remove newly-extracted version of '/usr/sbin/lightdm': Read-only file        system
 unable to remove newly-extracted version of '/usr/lib/arm-linux-gnueabihf/light        dm/lightdm-guest-session': Read-only file system
 unable to remove newly-installed version of '/usr/lib/arm-linux-gnueabihf/light        dm': Read-only file system
 unable to remove newly-extracted version of '/usr/bin/dm-tool': Read-only file        system
 unable to remove newly-extracted version of '/lib/systemd/system/lightdm.servic        e': Read-only file system
 unable to remove newly-extracted version of '/etc/pam.d/lightdm-greeter': Read-        only file system
 unable to remove newly-extracted version of '/etc/pam.d/lightdm-autologin': Rea        d-only file system
 unable to remove newly-extracted version of '/etc/pam.d/lightdm': Read-only fil        e system
 unable to remove newly-extracted version of '/etc/lightdm/users.conf': Read-onl        y file system
 unable to remove newly-extracted version of '/etc/lightdm/lightdm.conf': Read-o        nly file system
 unable to remove newly-extracted version of '/etc/lightdm/keys.conf': Read-only        file system
 unable to remove newly-extracted version of '/etc/init.d/lightdm': Read-only fi        le system
 unable to remove newly-extracted version of '/etc/dbus-1/system.d/org.freedeskt        op.DisplayManager.conf': Read-only file system
 unable to remove newly-extracted version of '/etc/apparmor.d/lightdm-guest-sess        ion': Read-only file system
 unable to remove newly-extracted version of '/etc/apparmor.d/abstractions/light        dm_chromium-browser': Read-only file system
 unable to remove newly-extracted version of '/etc/apparmor.d/abstractions/light        dm': Read-only file system
 unable to remove newly-installed version of '/etc/apparmor.d/abstractions': Rea        d-only file system
 unable to remove newly-installed version of '/etc/apparmor.d': Read-only file s        ystem
 unable to securely remove '/var/lib/dpkg/tmp.ci': Read-only file system
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/103-light-locker_1.8        .0-3_armhf.deb (--unpack):
 error ensuring '/var/lib/dpkg/reassemble.deb' doesn't exist: Read-only file sys        tem
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/104-lsb-release_10.2        019051400+rpi1_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/105-lxappearance_0.6        .3-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/106-lxappearance-obc        onf_0.2.3-1+rpt1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/107-lxpanel-data_0.1        0.0-2_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/108-lxpanel_0.10.0-2        _armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/109-pcmanfm_1.3.1-1_        armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/110-lxde-common_0.99        .2-3_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/111-lxsession-data_0        .5.4-1+rpt1_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/112-policykit-1_0.10        5-25+rpt1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/113-lxpolkit_0.5.4-1        +rpt1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/114-lxlock_0.5.4-1+r        pt1_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/115-lxsession-logout        _0.5.4-1+rpt1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/116-lxsession_0.5.4-        1+rpt1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/117-openbox_3.6.1-8+        rpt5_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/118-openbox-lxde-ses        sion_0.99.2-3_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/119-lxde-core_10_all        .deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/120-lxde-icon-theme_        0.5.1-2_all.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/121-lxhotkey-core_0.        1.0-1+b1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/122-lxhotkey-gtk_0.1        .0-1+b1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/123-xinput_1.6.2-1_a        rmhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/124-lxinput_0.3.5-1+        rpi9_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/125-lxrandr_0.3.2-1_        armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/126-lxsession-edit_0        .5.4-1+rpt1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/127-lxterminal_0.3.2        -1+rpt4_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/128-xarchiver_1%3a0.        5.4.14-1_armhf.deb (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/129-lxde_10_all.deb        (--unpack):
dpkg: error processing archive /tmp/apt-dpkg-install-yYo48P/130-upower_0.99.10-1        _armhf.deb (--unpack):
dpkg: error: unable to create new file '/var/lib/dpkg/status-new': Read-only fil        e system
E: Sub-process /usr/bin/dpkg returned an error code (2)
[FAILED] DietPi-Software | APT install for: lxde upower dbus-user-session
 - Command: apt-get -qq --allow-change-held-packages install lxde upower dbus-us        er-session
/boot/dietpi/func/dietpi-globals: line 822:  5972 Bus error               pgrep        -cf 'dietpi-config' &> /dev/null
/boot/dietpi/func/dietpi-globals: line 822:  5982 Segmentation fault      cat $f        p_error_report
[FAILED] DietPi-Software | Unable to continue, DietPi-Software will now terminat        e.
Hmm probably an issue with the SD card. Hope you did not reboot yet. Can you check for kernel errors
dmesg -l err,crit,alert,emerg
baremetaloctopus
I have not rebooted but:
root@DietPi:~# dmesg -l err,crit,alert,emerg
-bash: dmesg: command not found
This doesn't sounds healthy.
@MichaIng
Can you have a look please
baremetaloctopus
Okay, I appreciate your efforts!
Other than Jackett I have not really been using my DietPi. I set it up a few months ago to run Jackett, which has been working perfectly until very recently I noticed Jackett was missing indexers and it occurred to me how useful running a Discord client on the Pi could be.
As it took considerable time to configure my indexers with Jackett, if there is a chance I can recover the config with either of the methods in the thread I linked in the OP I would like to keep trying, but if you guys think I should start over with a new install I will.
Give time to the developer to join the discussion. Usually he has good ideas on such issues.
