PiHole Web Interface is not working
Re: PiHole Web Interface is not working
Well this is not really related to DietPi and it's version. It seems more your SD card has some issue as you loose SSH connectivity again as well right? Does a couple of reboot fix it again?
Caporeira
Post by Caporeira »
Yes, after reboot is fix it again (for few seconds power off every time is working again).
The partition is to small ? My card is 16 GB.
this has nothing to do with the size I would say. Probably your SD card is dying slowly.
Pls can you activate full log mode in dietpi-software. Maybe we will be able to see something next time once you need to reboot.
As well I would recommend to perform a backup. Best would be to use a USB stick as backup location.
pls can you share as well your file systems utilization
df -h
Caporeira
Post by Caporeira »
Full log mode has bin activated.
My file system utilisation:
root@DietPi:~# df -h
/dev/root        15G  1.6G   13G  12% /
devtmpfs        455M     0  455M   0% /dev
tmpfs           487M  1.1M  486M   1% /dev/shm
tmpfs           487M  8.7M  479M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           487M     0  487M   0% /sys/fs/cgroup
tmpfs            50M  324K   50M   1% /var/log
tmpfs           486M     0  486M   0% /tmp
/dev/mmcblk0p1  253M   50M  203M  20% /boot
tmpfs            98M     0   98M   0% /run/user/993
tmpfs            98M     0   98M   0% /run/user/0
DietPi has a few backups software. Is there any they can make a full system backup automatically (for example one time on a week) and store on USB stick?
you could use dietpi-backup. But there is no automation feature. You could create a simple script to have it executed once a week.
