Raspberrypi kernel headers Topic is solved
goldentk
Re: Raspberrypi kernel headers
Post by goldentk »
Ohh, that works, thanks bro :)
are you able to install the header now?
goldentk
Post by goldentk »
yes
goldentk
Post by goldentk »
Another question, I tried to compile driver for my network card but I'm getting this
Do you know what could go wrong?
DKMS make.log for rtl88x2bu-5.6.1 for kernel 5.10.17-v8+ (aarch64)
Thu May 27 11:15:24 CEST 2021
make ARCH=arm CROSS_COMPILE= -C /lib/modules/5.10.17-v8+/build M=/var/lib/dkms/rtl88x2bu/5.6.1/build  modules
make[1]: Entering directory '/usr/src/linux-headers-5.10.17-v8+'
  CC [M]  /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_cmd.o
gcc: error: unrecognized argument in option ‘-mabi=apcs-gnu’
gcc: note: valid arguments to ‘-mabi=’ are: ilp32 lp64
  CC [M]  /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_security.o
  CC [M]  /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_debug.o
gcc: error: unrecognized command line option ‘-mapcs’; did you mean ‘--specs’?
  CC [M]  /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_io.o
gcc: error: unrecognized command line option ‘-mno-sched-prolog’; did you mean ‘-Wno-sign-promo’?
gcc: error: unrecognized command line option ‘-msoft-float’
make[2]: *** [scripts/Makefile.build:279: /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_cmd.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [scripts/Makefile.build:279: /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_security.o] Error 1
make[2]: *** [scripts/Makefile.build:279: /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_debug.o] Error 1
make[2]: *** [scripts/Makefile.build:279: /var/lib/dkms/rtl88x2bu/5.6.1/build/core/rtw_io.o] Error 1
make[1]: *** [Makefile:1804: /var/lib/dkms/rtl88x2bu/5.6.1/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.10.17-v8+'
make: *** [Makefile:2284: modules] Error 2
I'm not a specialist in compiling stuff but I see you are using ARCH=arm. But your system is a 64bit Raspberry Pi OS and your would need to use ARCH="arm64" I guess. This would somehow fit the following I found on Google
https://github.com/gnab/rtl8812au/issues/170
