Windows 10 isn't seeing DietPi...
Nohippychicks
Re: Windows 10 isn't seeing DietPi...
Post by Nohippychicks »
After considerable time trying to fix this, I've come up with what I think is a solution:
I think some of my OS installs may have gotten somewhat corrupted; I haven't figured out how to check this, but the reason I believe this is that some of the issues were randomly corrected after I was forced to install a fresh version of the OS after a power outage corrupted the image I was using. This IS after I had tried several different OSs so....who knows?
Also, right now, I've SMB1 turned off and I can access the PI. I've tried a TON of different searches but what eventually worked is captured here:
https://community.spiceworks.com/topic/ ... ion?page=1
Now, I'm just going to go figure out how to get the USB drive to work with this whole situation.
Simply mount the drive using drive manager and change destination directory as described on our online docs https://dietpi.com/docs/software/file_servers/#samba
