Update to 7.1.2 - Wireguard broken Topic is solved
Re: Update to 7.1.2 - Wireguard broken
but a problem with my DDNS provider.
Probably the address got corrupted on their end. We never will find out. Do you regularly update your DDNS record using a script or update URL?
Sibbefufzich
Post by Sibbefufzich »
Yes, I update frequently (every 24 hours) using ddclient. Before you ask: Yes the problem persisted longer than 24 hours :P
was just an idea. ;)
Sibbefufzich
Yeah and often it's the small things which get overlooked, I guess you have quite the eye for those things by now :D
Feels weird not being able to provide a proper solution to the problem from my side for future solution seekers...
However: much thanks again to @Joulinar for providing a helpful (and idea rich) hand!
you're welcome, enjoy the rest of the day or have a good night
