RPI 2 Model B Rev 1.1 wrong RAM size ? Topic is solved
mtheofy
Re: RPI 2 Model B Rev 1.1 wrong RAM size ?
Post by mtheofy »
I get an error that the file is not found
curl -m 20 -sT ba398bb0-31e3-435a-b4b0-b5a5b2a8b67d.txt sftp://dietpi-survey:upload2dietpi@ssh.dietpi.com/survey/
curl: Can't open 'ba398bb0-31e3-435a-b4b0-b5a5b2a8b67d.txt'!
curl: try 'curl --help' or 'curl --manual' for more information
but if I create a dummy file it succeeds
# touch ba398bb0-31e3-435a-b4b0-b5a5b2a8b67d.txt
# curl -m 20 -sT ba398bb0-31e3-435a-b4b0-b5a5b2a8b67d.txt sftp://dietpi-survey:upload2dietpi@ssh.dietpi.com/survey/
-- Marcos
you can try to disable and enable the survey to see if it's working now. Just run dietpi-survey to switch settings
mtheofy
Post by mtheofy »
Joulinar wrote: Mon May 17, 2021 11:19 am you can try to disable and enable the survey to see if it's working now. Just run dietpi-survey to switch settings
Here's the output
# dietpi-survey
[  OK  ] DietPi-Survey | Setting in /boot/dietpi.txt adjusted: SURVEY_OPTED_IN=0
[FAILED] DietPi-Survey | Purging survey data
 - Command: curl -m 20 -sT ba398bb0-31e3-435a-b4b0-b5a5b2a8b67d.txt sftp://dietpi-survey:upload2dietpi@ssh.dietpi.com/survey/
# dietpi-survey
[  OK  ] DietPi-Survey | Setting in /boot/dietpi.txt adjusted: SURVEY_OPTED_IN=1
[FAILED] DietPi-Survey | Sending survey data
-- Marcos
hmm strange, the file is generated at run time in /tmp/DietPi-Survey and get removed afterwards. In your case it seems the file did not generate
can you open dietpi-survey and select Show. Does it display some data?
mtheofy
Post by mtheofy »
Yes it does - here's the dump
┌───────────────────────┤ DietPi-Survey | File viewer ├────────────────────────┐
│ #!/bin/bash        │
│ ((aDIETPI_VERSION[7.1]++))                                                   │
│ ((aGIT_BRANCH[MichaIng/master]++))                                           │
│ ((aDEVICE_NAME[RPi 2 Model B (armv7l)]++))                                   │
│ ((aCPU_ARCH[armv7l]++))                                                      │
│ ((aCPU_COUNT[4]++))                                                          │
│ ((aDISTRO_VERSION[buster]++))                                                │
│ ((aAUTOSTART_OPTION[${aAUTOSTART_NAME[0]:=0}]++))                            │
│ ((aAUTO_SETUP_AUTOMATED[0]++))                                               │
│ ((aNETWORK_INTERFACE[eth0]++))                                               │
│ ((aRASPBIAN[1]++))                                                           │
│ # DietPi-Software installs                                                   │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[0]:=0}]++))                                  │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[13]:=13}]++))                                │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[15]:=15}]++))                                │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[16]:=16}]++))                                │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[17]:=17}]++))                                │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[20]:=20}]++))                                │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[21]:=21}]++))                                │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[103]:=103}]++))                              │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[105]:=105}]++))                              │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[110]:=110}]++))                              │
│ ((aSOFTWARE[${aSOFTWARE_NAME7_1[130]:=130}]++))                              │
│ # DietPi-Benchmark                                                           │
│ BENCH_VERSION=2                                                              │
│ BENCH_HW_MODEL=2                                                             │
│ BENCH_CPU='Not tested'                                                       │
│ BENCH_ROOTFS_WRITE='13'                                                      │
│ BENCH_ROOTFS_READ='20'                                                       │
│ BENCH_RAM_WRITE='Not tested'                                                 │
│ BENCH_RAM_READ='Not tested'                                                  │
│ BENCH_CUSTOMFS_WRITE='10'                                                    │
│ BENCH_CUSTOMFS_READ='11'                                                     │
│ BENCH_CPU_TEMP_START='Not tested'                                            │
│ BENCH_CPU_TEMP_END='Not tested'                                              │
│ BENCH_NET_LAN_SPEED='Not tested'                                             │
│                                    <Ok>                                      │
-- Marcos
Strange
@MichaIng
Any ideas?
Strange, we'd need to add some debug code so that the curl (error) output is shown:
sed -i 's/G_EXEC_NOHALT=1/G_EXEC_OUTPUT=1/' /boot/dietpi/dietpi-survey
dietpi-survey 1
About GPU memory: I think we decided against setting GPU memory to minimum when headless gets selected as e.g. the RPi camera module or video encoding requires GPU memory as well but does not necessarily require a local screen. E.g. camera can be streamed to a website instead via mjpg-streamer or such.
But maybe we can reset GPU memory to min when the RPi camera module/extended GPU features are not enabled, i.e. the start_x=1 flag in /boot/config.txt :?.
mtheofy
Post by mtheofy »
Replying from a mobile phone. Hope it comes through OK :roll:
Hardware       | RPi 2 Model B (armv7l) (ID=2)
- Kernel version | Linux pollock 5.10.17-v7+ #1414 SMP Fri Apr 30 13:18:35 BST 2021 armv7l GNU/Linux
- Distro         | buster (ID=5,RASPBIAN=1)
- Command        | curl -m 20 -sT ba398bb0-31e3-435a-b4b0-b5a5b2a8b67d.txt sftp://dietpi-survey:upload2dietpi@ssh.dietpi.com/survey/
- Exit code      | 60
- Software title | DietPi-Survey
About the configuration options and the GPU memory allocation, I would vote in favour of your suggestion.. But, I am very new to the project.
-- Marcos
Exit code 60 means "Peer certificate cannot be authenticated with known CA certificates.": https://manpages.debian.org/curl#EXIT_CODES
Probably the SSH host key has been removed. Please try:
mkdir -p /root/.ssh
>> /root/.ssh/known_hosts
G_CONFIG_INJECT 'ssh.dietpi.com[[:blank:]]' 'ssh.dietpi.com ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDE6aw3r6aOEqendNu376iiCHr9tGBIWPgfrLkzjXjEsHGyVSUFNnZt6pftrDeK7UX+qX4FxOwQlugG4fymOHbimRCFiv6cf7VpYg1Ednquq9TLb7/cIIbX8a6AuRmX4fjdGuqwmBq3OG7ZksFcYEFKt5U4mAJIaL8hXiM2iXjgY02LqiQY/QWATsHI4ie9ZOnwrQE+Rr6mASN1BVFuIgyHIbwX54jsFSnZ/7CdBMkuAd9B8JkxppWVYpYIFHE9oWNfjh/epdK8yv9Oo6r0w5Rb+4qaAc5g+RAaknHeV6Gp75d2lxBdCm5XknKKbGma2+/DfoE8WZTSgzXrYcRlStYN' /root/.ssh/known_hosts
dietpi-survey 1
mtheofy
Post by mtheofy »
MichaIng wrote: Sun May 23, 2021 7:45 pm Exit code 60 means "Peer certificate cannot be authenticated with known CA certificates.": https://manpages.debian.org/curl#EXIT_CODES
mkdir -p /root/.ssh
dietpi-survey 1
Bingo! Probably the first thing I did after setting up Dietpi was to revert to sshd and copy known_hosts under ~/.ssh/
Just ran the "G_CONFIG_INJECT... " command and the key is now set.
thanks!
-- Marcos
