Writing to /var/www and other questions Topic is solved
Markstar
Re: Writing to /var/www and other questions
Post by Markstar »
Oh, how stupid of me. Using chmod -R g+rwx test/ did indeed fix the issue and now it works as intended!
Thank you so much again for your time and patience!
if you are coming from Windows, file system permissions doesn't seems logic. But if you get used to it, it's quite simple.
