Odroid XU4 not booting after update Topic is solved
Re: Odroid XU4 not booting after update
ok let's see. Maybe @MichaIng has an idea how to continue
Please try to attach a keyboard and press some random keys. This should fill the entropy pool required to continue booting.
Although, not 100% sure if its the entropy issue, since random: crng init done means that the initial filling has finished, if I recall correctly. Can you show the other boot messages before that one, so that we see which boot state has been reached?
Dks
Post by Dks »
Sorry for my late response. Wasn't home to test.
I attached a photo of the boot process until stop (I cant see the messages before :/). Hope you can find something that helps.
If I use an usb keyboard and press any key to fill the entropy pool nothing happens. It still stays in the message.
I guess you would need to hit buttons for a while
Dks
Post by Dks »
If I create a new "fresh" image of dietpi on another sd card. Is it possible to "mirror" the old one to get my homegear and homeassistant etc back?
There are a few more files around the filesystem and some other setup (system users) to get that back up. So I suggest, in case of Home Assistant, to only copy the /mnt/dietpi_userdata/homeassistant over from the old image (and in case other directories from /mnt/dietpi_userdata and install it then freshly via dietpi-software. It will migrate your data and configs then. homegear is a HA plugin, or a separate software? In case not sure where it stores data.
Aside of dietpi-software, in general /etc contains software configurations, so you might want to look for specific configs there to copy to the new system. And /var/lib contains data, so same here, copy individual sub directories over, where you require it. But do not copy both dirs completely, as many contained stuff is system-generated and specific for its particular system and package state. Copying both would cause a lot of issues with APT and other system tools ;). So generally, only copy over individual files/dirs where you know that you need it, configs files you manually heavily changed etc.
