docker-compose fails to install on Pine A64 on DietPi 7.1.2 Topic is solved
Re: docker-compose fails to install on Pine A64 on DietPi 7.1.2
The command from this post should fix it viewtopic.php?p=34245#p34245
You should be able to perfectly the installation afterwards
tfmeier
Post by tfmeier »
Joulinar wrote: Mon May 03, 2021 2:39 am The command from this post should fix it viewtopic.php?p=34245#p34245
hmm, the above URL brings me to my post or are you referring to the sed command?
sed -Ei 's@https://bootstrap\.pypa\.io/(3\.5/|)get-pip\.py@https://bootstrap.pypa.io/pip/\1get-pip.py@' /boot/dietpi/dietpi-software
meaning rather than starting the docker-compose install from the UI I simply use this command?
The installation is failing right? Therefore you need to run the sed command to apply a correction. This will adjust the installation script. Once done you can start the installation.
tfmeier
Post by tfmeier »
Yep. I figured that out in the meantime. Applied the `sed` command and re-ran the install.
Unfortunately it doesn't finish. Hangs halfway through the install. The attached shows the CPU at 100% although the RAM is only at about 30% (2GB RAM).
Tried to re-run without success. Stops at the same spot. Is there a way for me to delete the local cache and download the packages again or is there anything else I could try?
this could take time while compiling. Let it run for 1 hour pls.
tfmeier
Post by tfmeier »
It ran for more than 2 hrs before I killed it. Looking at the resource monitor I still see CPU% and time incrementing. Does this mean the process still runs? How long can I expect this to run?
Also what about the cache? The log says `Using cached ....`. Could this be corrupt or do the packages automatically refresh every time I restart the process?
Restarted the installation (still running after 1hr 45) but found this error earlier on the console
      running build_ext
      building '_cffi_backend' extension
      creating build/temp.linux-aarch64-3.5
      creating build/temp.linux-aarch64-3.5/c
      aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-XIOK8o/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.5m -c c/_cffi_backend.c -o build/temp.linux-aarch64-3.5/c/_cffi_backend.o
      c/_cffi_backend.c:15:17: fatal error: ffi.h: No such file or directory
       #include <ffi.h>
      compilation terminated.
      error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
  ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-66i57p6p/cffi_6d177a9a6c0742e0b6d476b839622794/setup.py'"'"'; __file__='"'"'/tmp/pip-install-66i57p6p/cffi_6d177a9a6c0742e0b6d476b839622794/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-759asbzg/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-0ekuz2br/overlay --compile --install-headers /tmp/pip-build-env-0ekuz2br/overlay/include/python3.5m/cffi Check the logs for full command output.
to clean the cache you could try running pip cache purge
Will do a test on my 64bit RPi4 as well now.
tfmeier
Post by tfmeier »
Ok. Let me know how you go.
As for my install it's now running for a good 11 hrs :) but still runs. My Internet connection is top (100Mbps) but it has been on the last step for at least 1 hr. Anyway I continue to let it run in hope it'll finish in the next few days :lol:
sorry for late response but got hijacked by my family 8)
11 hours is definitely way to long. Even on my old RPi1 it was finishing in less than 1 hour. Will run a test on my RPi4 64bit now.
That long time does not sound normal anymore. And the PINE A64 is not an RPi Zero, but quite capable.
The compilation error above indicates missing library headers:
apt install libffi-dev
