After dietpi upgrade crontab is empty? Topic is solved
Re: After dietpi upgrade crontab is empty?
cron should be restarted after the package update but your script is executed on reboot only. That's how you set it up using @reboot ;)
Ah yes @reboot is not triggered at cron restart, only on actual reboot :).
