Dietpi fail to find eithernet connection at boot time Topic is solved
Re: Dietpi fail to find eithernet connection at boot time
Makes sense up to a certain degree, if it's really different things. For the pure coding changes I can understand it, for the other thing not really, as it addresses one and the same issue. I'd have no problem with it, when knowing that the second change is still a matter of discussion, and if both resulting PRs would not be overwritten by a follow up change that can be foreseen already. But I get a blame when trying the check that in the first place. After all it's more about the tone than about the what, I guess. I know I've a too strong opinion as well that doesn't help. But I contribute to dozens of projects and never faced any comparable issues, never have problems to understand when/why a maintainer needs my PR changed, never run into any discussion, which is the strongest argument for myself that its at least not only my bullhead in this case. Also I never faced any issue with any other Pi-hole developer. I'm always happy when they merge a PR before Dan kicks in, as then it's nearly guaranteed to be delayed, causing us all additional efforts. There is another PR hanging for a year now, because he added some "This will break things" statements, ignoring any prove of the opposite, and as it should have been a companion for other PRs on the other Pi-hole orga repos, which have long been merged, this may earlier or later cause issues. But any attempt to have this information recognised is simply ignored.
It's hard but I need to learn being silent and either follow him or simply close the PR once I get the impression that time and nerves are wasted with a discussion :).
solution be going for a drink together. Usually this could fix such issues ;)
Possibly, but he literally lives at the other end of the world (Australia) :o.
still a missing part of the globe on my agenda :D
