Dietpi fail to find eithernet connection at boot time Topic is solved
mail2rst
Re: Dietpi fail to find eithernet connection at boot time
Post by mail2rst »
this command works "dmesg -l emerg,alert,crit,err". after executing next line show up for next command. so commands executed correctly
alone journalctl works & 1000 of line show up
alone dmesg command works & 1000 line show up
ip a command not exist
ifup etho command not exist
my dell usb keyboard not able to write pipe "|" for dmesg less command
puuh this means you don't have ip command as well as ifup?? This is more than bad as you will not be able to bring up the network interface without...
Still the question. Do you have a backup? As well can you check installation status of ifupdown package
dpkg -l ifupdown
It should looks like this
root@DietPi3:~# dpkg -l ifupdown
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version      Architecture Description
ii  ifupdown       0.8.35       armhf        high level tools to configure network interfaces
root@DietPi3:~#
Looks like you hit the same situation like this user viewtopic.php?f=11&t=8658
mail2rst
Post by mail2rst »
sorry, dietpi is so stable i never think to backup anything.
with "dpkg -l ifupdown" same line showup as your but in table none for version, architecture & in description(no description available)
it need to have ii at the beginning, indicating the installation status.
Following 3 packages would need to be available
dpkg -l ifupdown iproute2 isc-dhcp-client
mail2rst
Post by mail2rst »
with this command "dpkg -l ifupdown iproute2 isc-dhcp-client"
in table only shoup for ifupdown,
nothing for iproute2, isc-dhcp-client
one thing more, i have debian install live usb stick available if we can boot from it & repair dietpi. or you suggest better to reinstall everything again.
probably you removed iproute2 and isc-dhcp-client somewhere during your install/unstall procedure. I would recommend to reinstall all 3 packages. as you are offline with the system, you would need to download them on your computer and copy the packages via usb stick to your system. Let's check the architecture you are running on
dpkg --print-architectur
cat /etc/apt/sources.list
mail2rst
Post by mail2rst »
thanks Joulinar,
Its look like i did multiple damage to standard operating system. so instead of repairing it i will reinstall everything again. it will almost same headache. what you suggest?
your could give it a try to download the 3 packages and have them installed. Should not be that complicate and maybe faster than reinstall whole stuf. If you still face issues, you are always good to start from scratch. And once back online, do a backup ;)
mail2rst
Post by mail2rst »
dpkg command show me error & others works, the output from both as this image. https://pasteboard.co/JZudsKU.jpg
sorry again a typo
dpkg --print-architecture
