Limit partition size before first boot Topic is solved
vonloschz
Re: Limit partition size before first boot
Post by vonloschz »
here is my successful test over a MicroSD card.
* Disk info
sudo fdisk -l /dev/sda
Disk /dev/sda: 59.5 GiB, 63864569856 bytes, 124735488 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xe8af6eb2
# Image
PImage=DietPi_RPi-ARMv6-Buster.img
sudo dd if=${PImage} of=/dev/sda bs=4M conv=fsync
sudo sync
# Partitions
sudo parted -a optimal /dev/sda resizepart 2 67697654s      # 67697654 sector should bring the partition to 32GiB
sudo resize2fs /dev/sda2
sudo fsck.ext4 -fy /dev/sda2
sudo parted -a optimal /dev/sda mkpart primary 67698688s 124735487s
# Validation
0 error
sudo parted /dev/sda align-check opt
Partition number? 1
1 aligned
Partition number? 2
2 aligned
Partition number? 3
3 aligned
vonloschz
Post by vonloschz »
Then my tests errors over a SSD disk
* Disk info
sudo fdisk -l /dev/sdb
Disk /dev/sdb: 232.9 GiB, 250059350016 bytes, 488397168 sectors
I/O size (minimum/optimal): 4096 bytes / 33553920 bytes                                 <-- is it the problem ???
Disklabel type: dos
Disk identifier: 0x8f4dbd00
# Image
PImage=DietPi_RPi-ARMv8-Buster.img
sudo dd if=${PImage} of=/dev/sdb bs=4M conv=fsync
sudo sync
# Partitions
sudo parted -a optimal /dev/sdb resizepart 2 67697654s      # 67697654 sector should bring the partition to 32GiB
sudo resize2fs /dev/sdb2
sudo fsck.ext4 -fy /dev/sdb2
sudo parted -a optimal /dev/sdb mkpart primary 67698688s 488397167s
Warning: The resulting partition is not properly aligned for best performance.
Ignore/Cancel
# Partitions ... also in error..
sudo parted -a optimal /dev/sdb mkpart primary 68877285s 488397167s
sudo parted -a optimal /dev/sdb mkpart primary 68942820s 488397167s
sudo parted -a optimal /dev/sdb mkpart primary 68943872s 488397167s
vonloschz
Post by vonloschz »
SSD disk solution ...
I/O size (minimum/optimal): 4096 bytes / 33553920 bytes             4096 bytes = parted min alignment
        33553920 bytes = parted opt alignment
# Partitions
sudo parted -a optimal /dev/sdb resizepart 2 68870143s      # 67697654s = 32GiB / 68870143s = 32.6Gib
sudo parted -a min /dev/sdb mkpart primary 68870144s 488397167s
# Validation
0 error
sudo parted /dev/sdb align-check min
Partition number? 1
1 aligned
Partition number? 2
2 aligned
Partition number? 3
3 aligned
Sorry about this thread.... learning alone is so boring.
nothing to be sorry about, it's good learning and might be interesting for others as well :)
Interesting actually, thanks for sharing!
Interesting is that for my HDDs minimal and optimal alignment always leads to the same result. Everything is 512 bytes (like on your SD card). Probably my HDDs are too old :D, or it is more common on SSDs.
I wonder how 33553920 bytes is optimal, as it's 32767.5 KiB or 31.99951171875 MiB :?, at least a multiple of 512 bytes. Obviously this is very disk specific.
And then I wonder how the original boot and root partitions are aligned correctly. The first still starts at 4 MiB and the second at 260 MiB (4 + 256), which both is not a multiple of 33553920 bytes :?. Or did I get something wrong?
vonloschz
Post by vonloschz »
fyi ... this disk partitioning method
broke the installation over the new DietPi_RPi-ARMv8-Bullseye.7z image.
vonloschz
Post by vonloschz »
and the solution is ....
Because I made a zfs pool over the /dev/sdb3,
I feel that a wipefs over this disk before I dd the DietPi image help me.
But the real change was to not play anymore with the file system.
These 2 cmd broke the installation just before we get any networking.
Here is my final cmd to create a third partitions.
* Clean the disk and install DietPi image.
sudo wipefs --all /dev/sdb
sudo dd if=/tmp/DietPi_RPi-ARMv8-Bullseye.img of=/dev/sdb bs=4M conv=fsync
sudo sync
* Resize the second partition and create the third one.
* Copy the DietPiAutomation and a Custom_Script.
sudo mkdir -p /mnt/sdb1
sudo mount /dev/sdb1 /mnt/sdb1/
sudo cp ${DietPiAutomation} /mnt/sdb1/dietpi.txt
sudo cp ${Custom_Script} /mnt/sdb1/Automation_Custom_Script.sh
sudo umount /mnt/sdb1/
