WebIOPi doe snot work @ DietPi @ Raspberry Pi Zero W Topic is solved
torwan
Re: WebIOPi doe snot work @ DietPi @ Raspberry Pi Zero W
Post by torwan »
Joulinar wrote: Wed Apr 28, 2021 10:33 pm with next release, DietPi will switch to a different fork of WebIOPi that's working way better
https://github.com/MichaIng/DietPi/pull/4310
Still question if RasPi Zero /W will be supported. If not, an added note would be appreciated.
I tested it on a RPi1. Most probably it will work on a Zero W as well. It would be helpful if you have a spare SD card and could try it out.
It was not working on any RPi model, I guess due to incompatibility with recent Python versions. RPi Zero is not listed explicitly, and we couldn't test it (no RPi Zero here) but as Joulinar said: as it works on RPi 1 it should do on Zero as well, as they have the same 40 pins.
