[solved] DietPi 7.1.0 beta 64bit on RasPi4 apt upgrade failed Topic is solved
omavoss
Re: DietPi 7.1.0 beta 64bit on RasPi4 apt upgrade failed
Post by omavoss »
@Joulinar thank you for your hints.
The update now went without a hitch, only the system time is lagging behind by about 4 minutes per hour.
Many greetings.
Re: [solved] DietPi 7.1.0 beta 64bit on RasPi4 apt upgrade failed
if you switch to hourly update, it shouldn't be an issue. But still strange that your time is not synchron. On my RPi3B+ running dev branch it is still in sync after hours. Are you running some CPU intensiv operation on that board?
