nameserver into dhcpcd.conf vs resolv.conf Topic is solved
Re: nameserver into dhcpcd.conf vs resolv.conf
probably PiHole installer is writing it down based on what was selected during install process.
vonloschz
Post by vonloschz »
base on pi-hole git .... the setDHCPCD fonction inside pi-hole/automated install/basic-install.sh create this file.
yep that's the script DietPi is using to install PiHole. Basically that's what is used
INSTALL_URL_ADDRESS='https://install.pi-hole.net'
which will result in
https://raw.githubusercontent.com/pi-hole/pi-hole/master/automated%20install/basic-install.sh
vonloschz
Post by vonloschz »
I re-installed and set a static ip on dietpi.
will see if pi-hole create again this dhcpcd.conf.
in the past PiHole even changed DNS resolution to localhost but this changed in meantime
