Strict-Transport-Security" HTTP header is not set Topic is solved
przemko
Re: Strict-Transport-Security" HTTP header is not set
Post by przemko »
MichaIng wrote: Mon Nov 08, 2021 5:07 pm Did you use dietpi-letsencrypt? If so, run it again and enable HSTS there. It will then create the required config and enable it for Lighttpd.
Thanks. That works :)
Regards
Okay great :).
