Strict-Transport-Security" HTTP header is not set
eglider86
Re: Strict-Transport-Security" HTTP header is not set
Post by eglider86 »
tcp     LISTEN   0        80             127.0.0.1:3306          0.0.0.0:*
tcp     LISTEN   0        511            127.0.0.1:6379          0.0.0.0:*
tcp     LISTEN   0        1024             0.0.0.0:80            0.0.0.0:*
tcp     LISTEN   0        1000             0.0.0.0:22            0.0.0.0:*
tcp     LISTEN   0        1024             0.0.0.0:443           0.0.0.0:*
tcp     LISTEN   0        511                [::1]:6379             [::]:*
tcp     LISTEN   0        1024                [::]:80               [::]:*
tcp     LISTEN   0        1000                [::]:22               [::]:*
eglider86
Post by eglider86 »
yes i use letsencrypt. found that hsts, but after setting it to ON, it keeps falling back to OFF.
the output doesn't seems to be complete as it's missing the information about the program using these ports. Usually it should looks like this
root@DietPiProd:~# ss -tulpn | grep LISTEN
tcp     LISTEN   0        1000             0.0.0.0:22             0.0.0.0:*      users:(("dropbear",pid=706,fd=3))
tcp     LISTEN   0        256            127.0.0.1:5335           0.0.0.0:*      users:(("unbound",pid=527,fd=4))
tcp     LISTEN   0        4096             0.0.0.0:3000           0.0.0.0:*      users:(("docker-proxy",pid=1220,fd=4))
tcp     LISTEN   0        5              127.0.0.1:4711           0.0.0.0:*      users:(("pihole-FTL",pid=1858,fd=12))
tcp     LISTEN   0        5              127.0.0.1:6600           0.0.0.0:*      users:(("mpd",pid=847,fd=11))
tcp     LISTEN   0        4096             0.0.0.0:9002           0.0.0.0:*      users:(("docker-proxy",pid=1239,fd=4))
tcp     LISTEN   0        1024             0.0.0.0:80             0.0.0.0:*      users:(("lighttpd",pid=840,fd=4))
tcp     LISTEN   0        32               0.0.0.0:53             0.0.0.0:*      users:(("pihole-FTL",pid=1858,fd=7))
tcp     LISTEN   0        128              0.0.0.0:1333           0.0.0.0:*      users:(("mympd",pid=958,fd=3))
tcp     LISTEN   0        1000                [::]:22                [::]:*      users:(("dropbear",pid=706,fd=4))
tcp     LISTEN   0        4096                [::]:3000              [::]:*      users:(("docker-proxy",pid=1226,fd=4))
tcp     LISTEN   0        4096                [::]:9002              [::]:*      users:(("docker-proxy",pid=1247,fd=4))
tcp     LISTEN   0        1024                [::]:80                [::]:*      users:(("lighttpd",pid=840,fd=5))
tcp     LISTEN   0        32                  [::]:53                [::]:*      users:(("pihole-FTL",pid=1858,fd=9))
root@DietPiProd:~#
eglider86
Post by eglider86 »
tcp     LISTEN   0        50               0.0.0.0:445           0.0.0.0:*       users:(("smbd",pid=20382,fd=31))
tcp     LISTEN   0        80             127.0.0.1:3306          0.0.0.0:*       users:(("mysqld",pid=19558,fd=26))
tcp     LISTEN   0        50               0.0.0.0:139           0.0.0.0:*       users:(("smbd",pid=20382,fd=32))
tcp     LISTEN   0        511            127.0.0.1:6379          0.0.0.0:*       users:(("redis-server",pid=19486,fd=7))
tcp     LISTEN   0        1024             0.0.0.0:80            0.0.0.0:*       users:(("lighttpd",pid=19650,fd=4))
tcp     LISTEN   0        1000             0.0.0.0:22            0.0.0.0:*       users:(("dropbear",pid=426,fd=3))
tcp     LISTEN   0        1024             0.0.0.0:443           0.0.0.0:*       users:(("lighttpd",pid=19650,fd=6))
tcp     LISTEN   0        50                  [::]:445              [::]:*       users:(("smbd",pid=20382,fd=29))
tcp     LISTEN   0        511                [::1]:6379             [::]:*       users:(("redis-server",pid=19486,fd=8))
tcp     LISTEN   0        50                  [::]:139              [::]:*       users:(("smbd",pid=20382,fd=30))
tcp     LISTEN   0        1024                [::]:80               [::]:*       users:(("lighttpd",pid=19650,fd=5))
tcp     LISTEN   0        1000                [::]:22               [::]:*       users:(("dropbear",pid=426,fd=4))
ok you are running lighttpd as web server. You could do following to have HSTS activated. Pls use user root
cd /etc/lighttpd/conf-enabled
ln -s ../conf-available/98-dietpi-hsts.conf 98-dietpi-hsts.conf
service lighttpd force-reload
dietpi-services restart
eglider86
Post by eglider86 »
ok thanks, i will follow your instructions and will report back
eglider86
Post by eglider86 »
i have found an app to take care of it and it solved it. HSTS Header. Warning is gone.
Thank you
maybe you like to share what you have done ;)
eglider86
Post by eglider86 »
NC install in Apps at Tools section there is this app, i have downloaded and enabled.
Maybe you like to share the name of this app?
