SD card not being resized and first run startup failed Topic is solved
Re: SD card not being resized and first run startup failed
You can try to upload as zip archive
menacing_jon
Post by menacing_jon »
wait, this is so weird. when i put the sd card back in the raspberry pi, it works all of a sudden. the partition adjusted, no setup error
Maybe there was an issue reading the SD card correctly in first place which changed due to removal/put back in place
menacing_jon
i think so, not sure what the main problem that caused that
Well maybe an issue on the physical contact between SBC and SD card. Who knows. Good it is working now.
