Unable to boot into DietPi | Failed to load DietPi-Globals Topic is solved
sew3521
Re: Unable to boot into DietPi | Failed to load DietPi-Globals
Post by sew3521 »
You, my friend, are a genius. Everything is working now. I am going to start a new backup in a few minutes.
The only issue I ran into was fstab was not able to be written to at first because the partition was in read only mode. I fixed that using the command
mount / -o remount,rw
and was able to append your two lines.
Thank you again for all of the assistance. I really appreciate it.
can you do a reboot and verify all is working, including to be able to write to RootFS as well as BootFS. Usually r/o file systems indicates issues on the SD card
sew3521
Post by sew3521 »
Joulinar wrote: Wed Apr 14, 2021 4:06 pm can you do a reboot and verify all is working, including to be able to write to RootFS as well as BootFS. Usually r/o file systems indicates issues on the SD card
I feel silly asking this however I have very little Linux knowledge. Do I do this by making sure I can write a file to the root directory and the boot directory? If so, then I think everything is working. I was able to write a file "test.txt" to root and boot.
To make sure I am explaining everything correctly I have attached a screenshot.
yes that's basically right way. But it could be way simpler ;)
touch /test.file
touch /boot/test.file
touch will create the file right away and it is not needed to use nano
sew3521
Post by sew3521 »
Ah, very nice. Thanks :)
Ya, I just used Nano to make a test file at what I assumed each location would be. I have a few decades of Windows and Networking experience and am currently patching a 22 host VMware environment as I write this so I am not a complete tech noob... Just a noob when it comes to things I do not have experience with, like Linux :D
I was start supporting this project with just little knowledge on these thinks but it's growing over time, the more you look into it. And not to forget my best friend Google :lol:
sew3521
Post by sew3521 »
Google is my best friend as well. It is how I found out about the mount / -o remount,rw command I mentioned earlier. I also did quite a bit of Google-fu before opening up this thread.
yeah at the end we found it :)
good you are back online now
