Question about Unbound + Pi-Hole via Optimized Software
mail2rst
Re: Question about Unbound + Pi-Hole via Optimized Software
Post by mail2rst »
In dietpi configured unbound.conf, we are using root.hints file but not root.key file.
is root.key added some sort of security in our installation & processing process? in unbound documentation it is written something about root.key which updated many times in a day. i do not figure out yet what is the functioning of that process. is it any disadvantage to us not using that thing in standard dietpi installation.
not sure what you mean but on my system root.key is located at /var/lib/unbound
root@DietPiProd:~# ls -la /var/lib/unbound
total 16
drwxr-xr-x  2 unbound unbound 4096 May  3 14:52 .
drwxr-xr-x 25 root    root    4096 Apr 17 12:13 ..
-rw-r--r--  1 root    root    3313 May  1 01:52 root.hints
-rw-r--r--  1 unbound unbound  758 May  3 14:52 root.key
root@DietPiProd:~#
configuration is done with /etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf
root@DietPiProd:~# cat /etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf
server:
    # The following line will configure unbound to perform cryptographic
    # DNSSEC validation using the root trust anchor.
    auto-trust-anchor-file: "/var/lib/unbound/root.key"
root@DietPiProd:~#
mail2rst
Post by mail2rst »
thanks for information.
